OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: False.
OpenGL Allow Advanced Mode: False.
OpenGL Allow Old GPUs: Not Detected.
Video Card Vendor: Intel
Video Card Renderer: Mobile Intel(R) 4 Series Express Chipset Family
Display: 1
Display Bounds:= top: 0, left: 0, bottom: 900, right: 1440
Video Card Number: 2
Video Card: Mobile Intel(R) 4 Series Express Chipset Family
OpenCL Unavailable
Driver Version: 8.15.10.2555
Driver Date: 20111013000000.000000-000
Video Card Driver: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Video Mode:
Video Card Caption: Mobile Intel(R) 4 Series Express Chipset Family
Video Card Memory: 1804 MB
Video Rect Texture Size: 4096
Video Card Number: 1
OpenCL Unavailable
Video Mode: 1440 x 900 x 4294967296 colors
Serial number: Tryout Version
Which operating system are you currently running the Photoshop CS6 beta on? You'll also want to make sure that your drivers are up to date. It seems like they are out of date. This link may help: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFami ly=Graphics&ProductLine=Laptop+graphics+controllers&ProductProduct=Mob ile+Intel®+4+Series+Express+Chipset+Family
Keep in mind, that if you are running Windows XP, many GPU related features are not supported.
The driver in your report seems to be 8.15.10.2555. Looking at the link I posted above, the latest driver for your card, on Windows 7 64 bit, is 9.3.0.1019, which can be found below:
Verify that this driver is for your card, and update if necessary. Let us know if you see any change in Photoshop.
You can't compare Google Earth to what Photoshop CS6. Photoshop CS6 replies heavily on the GPU. Have you tried updating your drivers using the link I posted? Seeing that it's a 'mobile' card, I'm assuming you're using a laptop. If that's the case, upgrading your card would be very difficult, if not impossible.
Here is a link to a past discussion 2 years ago on the Intel chip and chipset. http://forums.adobe.com/thread/649763
Chris Cox said the Intel driver was not up to the task for Open GL, but Noel provided a workaround.
Perhaps this is still a valid method.
the first problem is you are using XP the second your graphics hardware.
AxCxS12 wrote:
Though Google earth runs perfectly. Can I buy a new graphics card or do I have to buy a new computer to be able to use Ps 6 fully. Does not seem right to me as Intel cards are common.
well i would love to run the latest software on my PII back from 1998 but it´s not gonna happen... ![]()
the GM45 and other 4 series chipsets are not that old... i admit.. but they are not meant for heavy graphic work either.
and it´s not only GFX cards who improve. the OpenGL standard improves too.
older GFX cards very often do not support the latest OpenGL version.
as this intel chipsets are not meant for graphic workstations, intel does not put much efford in the openGL drivers.
openCL is not supported at all with your GFX card.
thats not such a big problem with CS6 as only one feature is using openCL afaik (the new blur tools).
but it may be an issue in the future.
GPU and CS6:
http://forums.adobe.com/message/4294508
this is for CS5 (don´t know if hey have updated it for CS6 yet) but it gives a guideline for a good photoshop experience:
http://blogs.adobe.com/crawlspace/2011/05/how-to-tune-photoshop-cs5-fo r-peak-performance.html
This computer is a laptop and only two years old (Dell Vostro 1720) and not exactly crap. I am quite sure that I can plat World of Warcraft on it, though I have not tried yet, will have a try this afternoon. So what you are saying is that Inel are no good and I should by a new computer or not buy Ps 6? Or will I find Ps 6 so much better than Ps 4 regardless?
Does any of this help to explain? Or any information in my attachment?
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Windows 7 64-bit
Version: 6.1 Service Pack 1
System architecture: Intel CPU Family:6, Model:7, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
Physical processor count: 2
Processor speed: 2194 MHz
Built-in memory: 4057 MB
Free memory: 1838 MB
Memory available to Photoshop: 3473 MB
Memory used by Photoshop: 60 %
Image tile size: 128K
Image cache levels: 4
Display: 1
OpenCL Unavailable
Video Mode:
OpenCL Unavailable
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
Temporary file path: C:\Users\ACS\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
C:\, 218,2G, 56,5G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2012/01/18-15:07:40 66.492997 66.492997
adbeape.dll Adobe APE 2012/01/25-10:04:55 66.1025012 66.1025012
AdobeLinguistic.dll Adobe Linguisitc Library 6.0.0
AdobeOwl.dll Adobe Owl 2012/02/09-16:00:02 4.0.93 66.496052
AdobePDFL.dll PDFL 2011/12/12-16:12:37 66.419471 66.419471
AdobePIP.dll Adobe Product Improvement Program 6.0.0.1642
AdobeXMP.dll Adobe XMP Core 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPFiles.dll Adobe XMP Files 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPScript.dll Adobe XMP Script 2012/02/06-14:56:27 66.145661 66.145661
adobe_caps.dll Adobe CAPS 5,0,10,0
AGM.dll AGM 2012/01/18-15:07:40 66.492997 66.492997
ahclient.dll AdobeHelp Dynamic Link Library 1,7,0,56
aif_core.dll AIF 3.0 62.490293
aif_ocl.dll AIF 3.0 62.490293
aif_ogl.dll AIF 3.0 62.490293
amtlib.dll AMTLib (64 Bit) 6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00) 1.000000
ARE.dll ARE 2012/01/18-15:07:40 66.492997 66.492997
AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
Bib.dll BIB 2012/01/18-15:07:40 66.492997 66.492997
BIBUtils.dll BIBUtils 2012/01/18-15:07:40 66.492997 66.492997
boost_date_time.dll DVA Product 6.0.0
boost_signals.dll DVA Product 6.0.0
boost_system.dll DVA Product 6.0.0
boost_threads.dll DVA Product 6.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.0.5.19287 2.0.5.19287
CoolType.dll CoolType 2012/01/18-15:07:40 66.492997 66.492997
data_flow.dll AIF 3.0 62.490293
dvaaudiodevice.dll DVA Product 6.0.0
dvacore.dll DVA Product 6.0.0
dvamarshal.dll DVA Product 6.0.0
dvamediatypes.dll DVA Product 6.0.0
dvaplayer.dll DVA Product 6.0.0
dvatransport.dll DVA Product 6.0.0
dvaunittesting.dll DVA Product 6.0.0
dynamiclink.dll DVA Product 6.0.0
ExtendScript.dll ExtendScript 2011/12/14-15:08:46 66.490082 66.490082
FileInfo.dll Adobe XMP FileInfo 2012/01/17-15:11:19 66.145433 66.145433
filter_graph.dll AIF 3.0 62.490293
hydra_filters.dll AIF 3.0 62.490293
icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
icudt42.dll International Components for Unicode 4, 2, 0, 0
icuin42.dll International Components for Unicode 4, 2, 0, 0
icuuc42.dll International Components for Unicode 4, 2, 0, 0
image_compiler.dll AIF 3.0 62.490293
image_flow.dll AIF 3.0 62.490293
image_runtime.dll AIF 3.0 62.490293
JP2KLib.dll JP2KLib 2011/12/12-16:12:37 66.236923 66.236923
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 10.0
LogSession.dll LogSession 2.1.2.1640
mediacoreif.dll DVA Product 6.0.0
MPS.dll MPS 2012/02/03-10:33:13 66.495174 66.495174
msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
onOneToolboxPlus.dll onOne Toolbox2 Dynamic Link Library 2.2.0
ONProxySupport.dll TODO: 1.0.0.1
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CS6 CS6
Plugin.dll Adobe Photoshop CS6 CS6
PlugPlug.dll Adobe(R) CSXS PlugPlug Standard Dll (64 bit) 3.0.0.383
PSArt.dll Adobe Photoshop CS6 CS6
PSViews.dll Adobe Photoshop CS6 CS6
SCCore.dll ScCore 2011/12/14-15:08:46 66.490082 66.490082
ScriptUIFlex.dll ScriptUIFlex 2011/12/14-15:08:46 66.490082 66.490082
tbb.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 6.0.0.24
WRServices.dll WRServices Friday January 27 2012 13:22:12 Build 0.17112 0.17112
wu3d.dll U3D Writer 9.3.0.113
zlib.dll zlib 1.2.5
Required plug-ins:
3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Accented Edges 13.0
Adaptive Wide Angle 13.0
ADM 3.11x01
Angled Strokes 13.0
Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Bas Relief 13.0
BMP 13.0
Camera Raw 7.0
Chalk & Charcoal 13.0
Charcoal 13.0
Chrome 13.0
Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Color Halftone 13.0
Colored Pencil 13.0
CompuServe GIF 13.0
Conté Crayon 13.0
Craquelure 13.0
Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Crop and Straighten Photos Filter 13.0
Crosshatch 13.0
Crystallize 13.0
Cutout 13.0
Dark Strokes 13.0
De-Interlace 13.0
Dicom 13.0
Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Diffuse Glow 13.0
Displace 13.0
Dry Brush 13.0
Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Embed Watermark 4.0
Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Extrude 13.0
FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Fibers 13.0
Film Grain 13.0
Filter Gallery 13.0
Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Fresco 13.0
Glass 13.0
Glowing Edges 13.0
Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Grain 13.0
Graphic Pen 13.0
Halftone Pattern 13.0
HDRMergeUI 13.0
IFF Format 13.0
Ink Outlines 13.0
JPEG 2000 13.0
Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Lens Blur 13.0
Lens Correction 13.0
Lens Flare 13.0
Liquify 13.0
Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Mezzotint 13.0
Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Mosaic Tiles 13.0
Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Neon Glow 13.0
Note Paper 13.0
NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Ocean Ripple 13.0
Oil Paint 13.0
OpenEXR 13.0
Paint Daubs 13.0
Palette Knife 13.0
Patchwork 13.0
Paths to Illustrator 13.0
PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Photocopy 13.0
Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Pinch 13.0
Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Plaster 13.0
Plastic Wrap 13.0
PNG 13.0
Pointillize 13.0
Polar Coordinates 13.0
Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Poster Edges 13.0
Radial Blur 13.0
Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Read Watermark 4.0
Reticulation 13.0
Ripple 13.0
Rough Pastels 13.0
Save for Web 13.0
ScriptingSupport 13.0
Shear 13.0
Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Smart Blur 13.0
Smudge Stick 13.0
Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Spatter 13.0
Spherize 13.0
Sponge 13.0
Sprayed Strokes 13.0
Stained Glass 13.0
Stamp 13.0
Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Sumi-e 13.0
Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Targa 13.0
Texturizer 13.0
Tiles 13.0
Torn Edges 13.0
Twirl 13.0
U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Underpainting 13.0
Vanishing Point 13.0
Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Water Paper 13.0
Watercolor 13.0
Wave 13.0
Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Wind 13.0
Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
ZigZag 13.0
Optional and third party plug-ins:
Perfect Effects Free 3.0.2
Perfect Effects Free Filter 3.0.2
Perfect Effects Free Smart Filter 3.0.2
Plug-ins that failed to load: NONE
Flash:
onOne
Mini Bridge
Kuler
Installed TWAIN devices: NONE
sorry about mixing things up.. i was looking at another thread at the same time and that is why i thought your using XP. my fault.
OpenGL is a different beast then DirectX (WoW uses DirectX).
Your notebook is not bad but it is NOT .. lets say.. especially well suited for the latest graphic programs.
A dedicated GFX card in a notebook is generally a better choice, for graphic intense software, then integrated intel graphics.
Especially when it comes to software that needs OpenGL hardware support.
<<admin: there, I fixed it for you>>
-Agfaclack- wrote:
your notebook is not bad but it is not .. lets say.. especially well suited for the latest graphic programs.
a dedicated GFX card in a notebook is generally a better choice, for graphic intense software, then integrated intel graphics.
especially when it comes to software that needs OpenGL hardware support.
Believe you pulled a Curt and leff out the NOT. Should read "--- lets say - - NOT expecially well suited - - - "
The OpenGL support on older Intel graphics chipsets has been a problem for Photoshop (and Liquify). I strongly suspect the problem is the OpenGL support on your Mobile Intel(R) 4 Series Express Chipset is not strong enough even thought the laptop is relatively new. We found the latest Intel "HD Graphics" hardware OpenGL support to be much better. CS6 features like Liquify require a pretty powerful video card to work well.
Sounds reasonable. But still: "Ps detected graphics hardware that is not officially supported " and in my system info it says that open GL drawing is enabled. If my graphics hardware is not good enough, I will have to accept it. But if something is wrong whith my computer OR Adobe or Intel could fix it, then I would like to know. I would like Adobe to confirm definitly that my graphics harware is not good enough for Ps 6 or fix it.
AxCxS12 wrote:
…"Ps detected graphics hardware that is not officially supported " and in my system info it says that open GL drawing is enabled…
The message means exactly what is said. "Not officially supported" means it may work, partially or fully, but if it doesn't, Adobe can't help you.
This might be a long shot but easy enough to test. Disable the OnOne plug-ins and see if you get better behavior. They may be conflicting since they also use OpenGL.
regards,
steve
Thank you Steve!
I Disabled OnOne, as you advised me to try, as I really don´t need it. I have not yet seen any dfference but Ps might perform a little bit better whithout my knowing. Still Ps 6 seems so much better than Ps 4 (which is the version that I have) so I´ll go for it anyway. But I will not buy a new computer.
Best regards to you and all the others who have been helping me!
Ann-Christin
