DreamcastGuy
Install Error 1935 Adobe Premier Elements 10 Windows 7 64
Apr 21, 2012 9:01 PM
So Windows 7 looks like it's finishing up installing Premier Elements 10 when I get an error message and Windows rolls back the install.  I know others might have had similar issues but I haven't found any sort of solution that works.
I spent about 6 hours trying different things.  Trying to use safe mode and running without any extra services through MSconfig.
I even tried reinstalling NET Framework and changing the registry keys  (which I wasn't able to do since it won't let me delete the .NET Framework key even with permissions.)
I also downloaded the trial version of Premier elements but it came up with the same error message.
Here is what I keep on getting:
http://i516.photobucket.com/albums/u330/Dreamcastguy/Error.png
I will be calling the phone support on Monday but I have a feeling  they will say it's just something wrong with my computer.  Which I don't  think is possible because I was able to install the Vegas HD trial and  other programs easily enough.
    Apr 21, 2012 9:30 PM   in reply to DreamcastGuy
    Welcome to the forum.
    You might want to look over this ARTICLE, which is basically a checklist for general installations of Adobe programs.
    If nothing there helps, then see this LINK.
    Good luck,
    Hunt
    Apr 22, 2012 2:54 AM   in reply to DreamcastGuy
    You might try the Microsoft 'Fixit Tool' here: http://support.microsoft.com/fixit/. That solved a problem I was having with a program install/uninstall.
    I also had a problem where an application install kept rolling-back at the end. That problem was identified as being caused by too long a path name. I copied the install folder to a top level folder ( eg. C:\install) and that worked fine.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Apr 24, 2012 11:33 AM   in reply to DreamcastGuy
    Good news, a bit drastic but at least you're sorted out. Happy editing.
    Cheers,
    Neale
