Dreamweaver CS3 win 7 access denied
Apr 22, 2012 8:19 AM
I recently moved the OS (Win 7) to a SSD disk and reinstalled.
Now Dreamweaver CS3 don't let me save changes in the files ('Access denied').
I see that this has been an issue earlier, but have found no solution for me.
Read and write permissions are set on the folders for all possible users.
If I open the file in Notepad and make changes I can save it!
So why has Dreamweaver an 'access denied' to my files??
/Larry
    Apr 22, 2012 8:58 AM   in reply to LarryM01
    Sounds like something is wrong with the permissions on your system.  Are you an administrator on the system?  Also can you try creating a new admin user on the system and see if you are able to open files with that?
    Apr 23, 2012 7:15 AM   in reply to LarryM01
    LarryM01 wrote:
    .. and my only solution to this was to disable User Account Control (UAC) in Control Panel.
    Now Dreamweaver update files.
    But maybe there is a better way then disabling UAC?
    /Larry
    Only thing I can think of Larry is to create a new user account and start using that, eventually deleting your current corrupt account.  It sounds like OS level corruption with the account that permissions are not right from the move from the old HDD to the new one.  You should be able to bring over some of the data and settings and move it to the new account from the AppData folder on Windows.
    Unfortunately that's about the level most users stop at here.  Most users of this forum do not have the OS level expertise you would need to repair such an issue.You could go to a Windows support forum and see if there is a way to repair a corrupted OS user account and permissions.
    Jan 31, 2013 2:44 PM   in reply to LarryM01
    I had this problem with a Flashdrive. Drove me f'n nuts.  Try to save a file to the flashdrive - receive Access to *:\MFCxxxx.tmp DENIED.  Then the file vanished.  Could use Save As to save under another file name - no problem.  Or I could save, get error, file vanish, save again, file saved. FINALLY - The answer to my issue turned out to be, well, stupid.  (found on TechWorld)  Has absolutely nothing to do with permissions, Read Only status, etc, etc.  It may help some others with this situation.
    With Win Explorer open on the directory.  Click Organize, Layout, then turn off Preview Pane.
