I noticed that liquify is not very responsive (like with the release of cs5) this time it is impossible to choose a bush size smaller than 151 next step is 300 etc.
Also the image looks low res in liquify window ( i know this is not my mac pro machine, because everything works normal and fast in CS5.5)
Also the target is way to thick and large and makes it difficult to see the image when applying local liquifying tool.
Same goes for target when using path tool...it is possible to make the targets thinner/smaller or more opaque?
you probably have a video card driver that needs a driver update or your card is upsupported.
see this thread:
http://forums.adobe.com/message/4286232#4286232
if you launch liquify holding down option you will launch in CPU mode - which is the same as CS5. you wont have a pixelated preview.
they dont really talk much about many people having to use CPU mode.
I am using a 3 month old ATI Radeon HD 5870 graphics card in a 2.8 GHz Quad-Core Intel Xeon with 8GB of ram and I am having no problems in CS5.5
also I don't like the fact that I have to use Alt/Opt !! If I use my wacom intuos5 pen and want to select a number between 1 and 151 I should be able to! Don't you think??
As for the path tool.... I would like it when they offer an option to make the symbol more opaque.. I know it's there but prefer to see the area where I am working on and see a little less of the marching ants and the crosshair etc.. (this is not a bug, just a suggestion!)
I went to the AMD.com website but there are no updates for the driver
Can't find a driver upgrade for my graphics card and frankly never heard anybody talk about this or have never done this.
Why would don't I have any problems in CS5.5?
Okay tried help and typed in system info but nothing but set system preferences comes up
here is what I can find in my mac pro under graphics/Displays
ATI Radeon HD 5870:
Chipset Model: ATI Radeon HD 5870
Type: GPU
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 1024 MB
Vendor: ATI (0x1002)
Device ID: 0x6898
Revision ID: 0x0000
ROM Revision: 113-C0780C-194
EFI Driver Version: 01.00.436
Displays:
LED Cinema Display:
Resolution: 2560 x 1440
Pixel Depth: 32-Bit Color (ARGB8888)
Display Serial Number: W81473ML6JL
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
Connection Type: DisplayPort
Cinema HD Display:
Resolution: 1920 x 1200
Mirror: Off
Online: Yes
Rotation: Supported
Hope this helps
Liquify was heavily reworked for CS6. So most parts of it are different from CS5.5. A great deal of GPU acceleration was added.
If your Liquify preview has a one pixel black border then you are in CPU mode, not the accelerated GPU mode. If Liquify is starting in CPU mode you can press the control key immediately after starting it and it will show and alert telling you why it could not run in the accelerated GPU mode on your Mac.
-John
