Hi
my code below is working fine except the css didn't work if i have scope="row" in report.cfm page. if i removed that line, then the front size worked fine, otherwise, it was small. I always have td scope in the cfm page with css with those style and it worked fine, but don't know if scope has something to do with cfdocument?
thanks
report.cfm
<cfif form.submit neq "">
<cfsavecontent vairable="session.report">
<td scope="row">My Report</td>
</cfsavecontent>
#session.report#
</cfif>
<a href=pdf.cfm">view pdf</a>
pdf.cfm
<cfset request.theReport = session.report />
<cfdocument format="pdf" orientation="landscape" marginRight=".5" marginLeft=".5">
<style>
body, table, th, td {font: normal normal normal 15px/normal, Arial;
</style>
<cfoutput>
#request.theReport#
</cfoutput>
</cfdocument>
Include all the HTML table tags, table, tr, th, and so on, in report.cfm.
It just an example, but ofcouse i have all table tags in my report.cfm
Could you then reproduce the code as close as possible to the version in which the error occurs? Just to rule out the obvious. I cannot tell you the number of threads I have participated in, where more than 20 posts had passed before the original poster realized he had simply put a dot in the wrong place.
