row count in datagrid
Apr 23, 2012 5:11 AM
Hi All
rowCount property of datagrid not working.
Any suggestions?
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="white" layout="vertical" viewSourceURL="srcview/index.html">
<mx:Array id="arr">
  <mx:Object articleName="Finding out a characters Unicode character code" data="15" />
  <mx:Object articleName="Setting an icon in an Alert control" data="14" />
  <mx:Object articleName="Setting an icon in a Button control" data="13" />
  <mx:Object articleName="Installing the latest nightly Flex 3 SDK build into Flex Builder 3" data="10" />
  <mx:Object articleName="Detecting which button a user pressed to dismiss an Alert dialog" data="9" />
  <mx:Object articleName="Using the Alert control" data="8" />
  <mx:Object articleName="Formatting data tips in a Slider" data="7" />
  <mx:Object articleName="Downloading the latest Adobe Labs version of Flex 3 SDK/Flex Builder 3 (codename: Moxie)" data="6" />
</mx:Array>
<mx:ArrayCollection id="arrColl" source="{arr}" />
<mx:DataGrid rowCount="9" id="dataGrid" dataProvider="{arrColl}" variableRowHeight="true" width="100%" height="100%">
  <mx:columns>
   <mx:DataGridColumn id="articleName" dataField="articleName" headerText="Name of the article in question" wordWrap="true" />
   <mx:DataGridColumn id="data" dataField="data" headerText="ID of the article" />
  </mx:columns>
</mx:DataGrid>
</mx:Application>
    Apr 23, 2012 5:21 AM   in reply to KapilArora021983
    you might get a better response on the flex forum but when you say not working what do you mean?
    Apr 23, 2012 5:26 AM   in reply to _spoboyle
    I have just ran your code and get 9 rows, are you aware you only have 8 rows of data
    Apr 23, 2012 5:46 AM   in reply to KapilArora021983
    I expect that's something to do with the datagrid height. the row count is still 9 if you trace it out
    if the height of the datagrid is more that the data can fill I expect you get the extra rows displayed.
    if you launch your application and resize it smaller you will notice you don't see these extra rows.
    depending on what you are trying to achieve you may have to listen to the change event of datagrid and manually resize the datagrid's height as the sum of the row heights
    Apr 23, 2012 5:49 AM   in reply to _spoboyle
    simply removing the height="100%" might also achieve what you are after
