Updating
Apr 23, 2012 9:01 AM
I have been working on restructuring some of my code. I did this by making an index_test.htm
I am wondering how do i make the index_test.htm into the index.htm
The main problem i am having is how to change my previous template to reflect the changes.
Here is the site:
http://www.humboldt.edu/cicd/index_test.htm
Any help would be appreciated
-Overtim3
    Apr 23, 2012 9:05 AM   in reply to Overtim3
    The easy way would be to save your current index.htm as index_OLD.htm (or similar) and then rename index_test.htm as index.htm.Upload the new index.htm and it will overwrite the old one.
    Apr 23, 2012 9:23 AM   in reply to Overtim3
    There are a couple of ways you could do this. You could:
    • Turn your index_test.htm into a template and set the editable regions again. You can then rename the template (main.dwt becomes main_OLD.dwt and you create a new main.dwt).
    • If you remember the changes you made, just make them again in the main.dwt file. If I remember correctly, most of the changes were made in the CSS so connect up the CSS sheet and then move the HTML sections around in the template (I remember these were 'out of normal order').
    As long as the editable regions in the new main.dwt are the same as the old ones, the site should have no problem updating but maybe someone with more recent knowledge on template usage would have a better informed solution for you.
    Apr 23, 2012 9:45 AM   in reply to Overtim3
    No problem, glad you got it sorted. If you need to add additional regions, they can be found in "Insert > Template Objects > Editable region".
    Good luck with the rest of the site.
    Rik
    Apr 23, 2012 9:53 AM   in reply to Overtim3
    When you open and save the .dwt file, it should prompt you to update all child pages. If you select yes, it should go through all pages within the site and update. You need to upload every page to the server again. But - make sure you test that the updated .dwt file has worked and that nothing else has changed on any of the pther pages before you upload them to your server. That way, if anything is wrong, you can download the unchanged server examples and try again.
    Apr 23, 2012 10:05 AM   in reply to Overtim3
    A content management system would be used for sites with a large number of pages. HTML pages are relatively low in filesize so uploading 15-20 after a template update would not be an issue but some people use Server Side Includes for things like navigation and the footer so they have less updates to make within the template itself.
