Creating own controller
Apr 22, 2012 1:36 PM
There are parts of my movie where I want the user to have complete control. So I created a controller with step back, pause, step forward, play.
Any help with script would be appreciate. I have tried go to the frame for stop --- and even put it in a loop - but it doesn't stop
I have tried frame+1 for step forward without any lock.
How do control frame movement.
I would prefer not to use markers - because the count would be in the thousands.
    Apr 22, 2012 3:51 PM   in reply to bmohnsen
    When you say
    are you talking about your Director movie or a video file you have playing on the stage?
    Apr 23, 2012 12:57 AM   in reply to bmohnsen
    And so you're wanting a controller something like the QuickTime controller, with a play/apuse button and a sliding scrub bar?
    Apr 23, 2012 11:31 AM   in reply to bmohnsen
    One way to approach this is to place all the logic for controling the position of the timeline in a parent script and then use a global exitFrame handler inside a movie script to route the call to an instance of the parent script.
    It's simpler than it sounds.
    Here's the movie script:
    global gControler
    on prepareMovie
      gControler = script("Timeline Controler").new(#play)  -- #play, #pause, #reverse. [speed] optional speed value
    end
    on exitFrame
      gControler.updateFrame()
    end
    Now you can control the flow of the timeline via the global object "gControler" which I provide below.
    The interface is:
    gControler.play(), gControler.play(3), etc
    gControler.reverse(), gControler.reverse(2), etc
    gControler.pause()
    gControler.jump(1), gControler.jump(10), etc
    gControler.seek(10), gControler.seek(1000), etc
    Any exitFrame handlers in FrameScripts will override the movieScript exitframe handler. Which you may or may not want to do.
    Paste the following in to a parent script named: "Timeline Controler"
    -- Parent Script Timeline Controler
    property  pState  -- #play, #pause, #reverse
    property  pSpeed  -- frames per exitFrame. Normal play rate is 1.
    on new me, aState, speed
      if aState.SymbolP then
        pState = aState
      else
        pState = #play
      end if
      if Not [#play, #pause, #reverse].getPos(pState) then pState = #play
      if speed.IntegerP then
        pSpeed = speed
      else
        pSpeed = 1
      end if
      return me
    end new
    -- change current frame based on state variable pState
    on updateFrame me
      case pState of
        #play:       go(min(_movie.frame + pSpeed, _movie.lastframe))
        #reverse:  go(max(1, _movie.frame - pSpeed))
        #pause:    go(_movie.frame)
      end case
    end updateFrame
    -- go forwards
    on play me, speed
        pSpeed = speed
      else
        pSpeed = 1
      end if
      pState = #play
    end play
    -- go backwards
    on reverse me, speed
        pSpeed = speed
      else
        pSpeed = 1
      end if
      pState = #reverse
    end reverse
    -- loop on a frame
    on pause me
      pState = #pause
    end pause
    -- move "pos" number of frames from current position. Can be positive or negative
    on jump me, pos
      if pos.IntegerP then
        go(max(1, min(_movie.frame + pos, _movie.lastframe)))
      end if
    end jump
    -- go to an absolute position on the timeline
    on seek me, pos
        go(max(1, min(pos, _movie.lastframe)))
      end if
    end seek
