master ExtendScript to run FrameMaker and RoboHelp scripts?
Apr 18, 2012 11:02 AM
I'm trying to automate generation of PDF in FrameMaker 10 and WebHelp from the same source in RoboHelp 9.
I have two scripts that are working, now I'm trying to run them as a single script.
Looking at a discussion about InDesign scripting (http://forums.adobe.com/thread/776832), I thought maybe the following would work:
robohelp.executeScriptFile("c:\\Users\\rlauriston\\Documents\\help_aut omation\\2_robohelp.jsx")
but when I debug it in ExtendScript Toolkit CS5.5, I get "robohelp is undefined".
Reading Adobe Creative Suite 5 JavaScript Tools Guide, I get the impression that this should work:
robohelp.executescript(
var projectPath = "C:\\Users\\rlauriston\\Documents\\My RoboHelp Projects\\AG\\SentrionAdminGuide.xpj";
main();
function main()
        if(projectPath == "")
               //Error!. Quit RoboHelp
               alert("Project path is not defined. \nPlease update the 'projectPath' variable in the script.");
               RoboHelp.quit();
        RoboHelp.openProject(projectPath); //Open the project
        RoboHelp.project.updateAll(true); //Update all linked documents (pass true for Force update)
          RoboHelp.closeProject(); //Close project
        RoboHelp.quit(); //Quit RoboHelp
but when I debug it I get "Illegal use of reserved word 'var'". If I move the var declaration to the top of the file, I get "Expected: )" on the semicolon after main().
    Apr 18, 2012 11:54 PM   in reply to rlauriston
    As far as I can make out, everything after robohelp.executescript is considered an argument for the function executescript. Opening RoboHelp and run a script, see http://help.adobe.com/en_US/robohelp/robohtml/WS98613C7C-EF5B-48e9-A91 A-D2AABB882687.html
    For running both applications from a single script, I’ve been told you can use the Bridge features. But I’ve never seen an example of that.
    Greet,
    Willam
    Apr 20, 2012 6:33 AM   in reply to rlauriston
    I have absolutely no idea as I haven’t used FM scripting. You will probably have better luck asking this on the FM forum: http://forums.adobe.com/community/framemaker
    But you could write a script you run in framemaker that starts RoboHelp with the script you want to run.
    Greet,
    Willam
    Apr 23, 2012 11:57 AM   in reply to rlauriston
    Not that I know. But I was thinking along the lines of running the script in FM, then writing a batch file in ExtendScript that launches RH and the script that should be run.
    Greet,
    Willam
    Apr 23, 2012 12:39 PM   in reply to rlauriston
    For working with fileObj, you first need to create a file object.
    //Create bat file object
    var mybat = new File(“C:/mybatfile.bat”);
    //Create content
    var content = “\ndel /F /! \”” + mybat.fsName + “\””;
    //Write content to bat file
    mybat.open(“w”);//This will open for writing and create if not exists
    mybat.write(content);
    mybat.close();
    //Run the bat file
    mybat.execute();
    If you want more examples, check the ePub generation script in RoboHelp 9. That uses the function writeFile (if I’m not mistaken) to write to a file.
    Greet,
    Willam
    Apr 23, 2012 10:30 PM   in reply to rlauriston
    Indeed.when the file exists you can skip the step. But you have to be sure that the bat file contains the correct commands.
    Greet,
    Willam
