Finding the end of line
Apr 23, 2012 12:08 PM
Is It possible to find and change a character in the end of each line from a block text?
I know Indesign GREP can't do this, GREP only finds the end of paragraph, not lines.
I understand this is a problem because every time the text frame is modified, you have another character being changed.
Is It possible to do this with a script?
I have attached an image of what I would like to do.
The text in the image is Hebrew (R2L language) and the end of line is in the left.
Any help would be great.
Sami
    Apr 23, 2012 12:36 PM   in reply to Sami Artur
    Well, if you've got some text (paragraphs, story, whatever):
    myText.lines.characters[-1]
    will get you the last character on the line.
    If you want to change what it is,
    myText.lines.characters[-1].contents = "Z"
    etc.
    Ariel
    Apr 24, 2012 5:35 AM   in reply to Sami Artur
    It depends on how you're getting hold of the block of text.
    Let's say you select a paragraph in InDesign.
    So then  you can say:
    myPara = app.selection[0];
    then the lines in this paragraph are:
    myLines = myPara.lines;
    so now you can do a loop:
    for (var i =0; i<myLines.length; i++){
    now let's say you've set you app.findTextPreferences and app.changeTextPreferences to whatever you want, you can search the line as follows:
    myFinds = myLines[i].findText();
    and the last find on the line will be:
    myFinds[-1]
    so you can change that to whatever you want:
    myFinds[-1].contents = "Z";
    If you want to substitute justification alternatives with regular letters it's obviously a little more complicated (you've got to find the unicode values, etc.) but this is the basic idea.
    One thing you've got to be careful about is that if you make a replacement, the lines shouldn't change. If the line breaks change, myLines will no longer be valid and you can get some weird results.
    HTH,
    Ariel
    Apr 24, 2012 2:58 PM   in reply to Sami Artur
    Assuming your text is inside one or more text frames which are connected. Select one of them and run this:
    myLines = app.selection[0].parentStory.lines;
    for (k=0; k<myLines.length; k++){
         if(myLines[k].characters[-1] == "\r")                         // if there is an end of paragraph
              myLines[k].characters[-2].contents = "z";          // change a second last character to "z"
         else myLines[k].characters[-1].contents = "z";     // otherwise change a last character to "z"
    This is just for show the way.
    Hope you step into
    Oct 17, 2013 2:06 PM   in reply to Jump_Over
    Hi there!
    I am trying to figure out how to modify the script that can look for last one or two last words (widows/orphans) in the line that starts after the period. Would script be able to add No Break GREP or character style?
    Peter
    Oct 17, 2013 3:57 PM   in reply to Peter Stnsz
    It could work with nested Grep which is applying "noBreak" charStyle.
    expression for the last word: \x{20}\b\w+\b.$
    expression for two last words: (\x{20}\b\w+\b){2}.$
    Jarek
    Oct 23, 2013 12:29 AM   in reply to Jump_Over
    Hi Jarek,
    Thank you for the answer. Your GREP works, however not the way I wanted. Works quite similar to the solution that I am using at the moment: nested NoBreak style with GREP .{8}$ (so It won't leave any short words at the end of the paragraph).
    The solution I am looking for is to find a script that will push these words to the next line (within the paragraph, not only at the end of the paragraph), here is what I mean - I would like to move this 'orphan' word to the next line:
    I presume I will be not able to make that with GREP itself?
    Peter
    Oct 24, 2013 2:47 AM   in reply to Peter Stnsz
    so maybe try:
    \b.{2}\b\s
    Jarek
    Nov 20, 2013 3:57 AM   in reply to Jump_Over
    Hello Jarek,
    This will actually work. Thanks!
