I get this message when I open some InDesign files: 'InDesign CS5.5 has stopped working'. After this I have to close InDesign. How can I stop it from doing this?
Holly, did you search for the whole path, or did you look inside the Users folder for your account? I'd expect it'd look something like this:
C:\Users\Holly\AppData\Roaming\Adobe\Adobe InDesign Version 5.5\English
Because we don't know how your computer is set up, you'd need to use the paths that Manish posted to figure out where your versions of these files are located.
I think I've found the InDesign recovery folder but where do I move it to?
I think that if you just move it away from that location to another place where you can find it easily if you ever need to find it and put it back where it came from (for example, your desktop) then that would probably be enough.
That's one. You can move the whole folder if you like, but the only file that probably matters in it is InDesign Defaults.
The other path will be C:\Users\Holly\AppData\Local\Adobe\InDesign\Version 7.5\en_GB\caches and you'll want to delete, move or rename InDesign SavedData.
For more complete directions see http://forums.adobe.com/thread/526990
Were you trying to open the same documents? You should be checking with different files, and you should empty the recovery folder again first.
Once that you've emptied the recovery folder, start ID from the start menu or a shortcut -- don't double-click a file to open, and see if ID will launch successfully. If it does, create a new file, save and close it (just add a randome text frame and fill with placeholder text for the test). Can you reopen that from the File > Open... dialog? How about after closing and restarting ID?
Did you actually MOVE the links to your desktop, so they were no longer in the old location, or COPY the links to the desktop so they were in both places? If you copied them, ID can still find the originals and we won't get the file to open if one of them is corrupt. It is essential that they no longer be where ID is going to look for them automatically, which means not in the original location, and not in the same folder, or a subfolder of that folder, where the .indd file located.
I created a new user account and tried to open the file but it came up with the 'InDesign CS5.5 has stopped working' message and closed.
I copied the links to my desktop so they are both on the network at work and on my desktop. Now that I am not connected to the network with the original links shouldn't it work? The only links InDesign could find now would be the ones on my desktop.
Apologies for replying late....
Can you check one more thing i.e, to disconnect from the network or server where these file were saved and then open the file from the folder on the desktop and check.
Disconnecting from the network will make your machine standalone and better enviorment to check.
Just check and let us know , once you have done your testing you can re-connect to the network.
Message was edited by: Manish_1988
