Using Acrobat Pro how do I lock the fillable fields once the data is collected?
Total Likes
Have a look at Paul's LockAllFields solution. You can download it in Paul's post here: http://forums.adobe.com/message/3168183#3168183.
I have a version of it here as well: http://assure.ly/yDtfsM.
Hope that helps,
Niall
Total Likes
Ok I see it but how do I copy it into my form? Or do I need to write a script for it?
Also should I be using LiveCycle instead of Acrobat Pro for this function?
Total Likes
Hmmm...
Did you create the form in LiveCycle Designer (XFA Forms)? Or in Acrobat (AcroForms)?
The solution I posted is for forms created in LiveCycle Designer.
You will be able to lock fields in AcroForms, but I think you would need to target each field individually (eg a different solution to the one posted). If you have created your form in Acrobat, you may get better advice on the Acrobat forums.
Hope that helps,
Niall
Total Likes
Created it in Acrobat X Pro
Total Likes
