Printing What I Want
Apr 23, 2012 11:56 AM
Tags: #print #printing_problem #printing_settings
An elementary question, I'm sure, but if there some way I can print what I want of the document? In my image, you can see in the print preview the pink box that shows what will be printed. Any way I can move that pink box over a little to the right because it's cutting off my document, or any way I can get rid of it completely so I can print my entire document?
Thanks for the help!
    Apr 23, 2012 12:00 PM   in reply to JDagger
    Before going to the Print dialog, zoom into the area you want to print.
    Then press Ctrl+P and under More Options select Current View.
    Apr 23, 2012 4:14 PM   in reply to JDagger
    Your printer cannot print to the edge of the sheet of paper.
    In the preview window, the gray area is the area of your printer that cannot be printed to, and these areas are unique to different printers. As a rule, laser printers have a quarter inch unprintable area all four sides and ink jets (perhaps older less expensive ink jets) can have as much as one inch at the bottom which cannot be printed to.
    You would need a printer which supports boarderless printing, or print the document to a larger size sheet (tabloid) and trim to the proper margins.
