Fretfive
Using the Escape key in simulations and assessments
Apr 19, 2012 12:30 PM
Tags: #in #key #using #the #escape #simulations
I have recently recorded a simulation/assessment that needs to use the Escape key to close a pop-up window and returns to the main application window. The recording has not been an issue; however, using Escape with failure messages is proving to be tricky.  Here's what I have discovered while resording my sim/assess, along with my questions:
  • When I press Escape, Captivate captures this keystroke as a shortcut attached to a Click Box. This works on the assessment side, but fails to produce a failure message on the assessment side when the user does not press the Escape key.
  • I need to produce a failure message when the user  does not press Escape.
  • Can I storethe unicode value of Escape in a TEB variable and then use an if . . . else statement to either advance to the next slide (success action) or produce a caption that mimics a failure caption?  If so, how would I write this item?
  • Could I use a Loss of focus trigger instead?
  • Does Captivate have a variable that records a unicode value (Something like CPKeyPressedValue"?
  • Are there any other alternatives?
    Apr 19, 2012 8:31 PM   in reply to Fretfive
    Captivate triggers success or failure based on events.  So if your user clicks the correct object a success criteria is triggered by their correct action.
    If you are using a click box over a specific area of the screen that the user is supposed to click, then clicking outside that area will register a Failure.
    In your case, what are you intending to use as the incorrect action or event?  Will the user be pressing some other key, or clicking some other object? If so, then you should be able to structure the interaction to register anything other than the desired action as a failure.
    I haven't heard of anyone using unicode values in a TEB to mimic a failure.  That might require some ActionScript coding and possibly a widget to pull off.
    Apr 23, 2012 5:53 PM   in reply to Fretfive
    In the case of buttons and clickbox objects, where clicking is allowed, the failure is normally registered when the user CLICKS OUTSIDE the button or click box.  The evaluation of Success/Fail happens on the click.
    In the case of a Text Entry Box, the interactivity is all about what the user enters into the text field and whether or not it is correct/incorrect when compared to approved answer text.  The main purpose of the TEB object is not centered on the clicking of the button that accompanies the text field.  The button just provides a way to trigger the Success/Failure evaluation of the user interaction with the text field.
    Since you have deselected Allow Mouse Click for your click box, you've effectively made it mandatory to use keystrokes to trigger the Success/Failure evaluation of the object. So clicking outside the box is no longer going to do anything because Allow Mouse Click is off.  You'll get a failure message on this click box now for many (but not all) keystrokes that are not the one assigned.
    By the way, using the Escape key as a keystroke if you Preview the project in Captivate just shuts down the preview (as you've probably already found out).
