Newbie question on Site Map Creation
Apr 23, 2012 3:53 PM
Does Dreamweaver has a feature that can automatically create a sitemap?  I heard that it is better to use XML to create a site map to help SEO ranking?  Any reference you can refer is a big help.
Thank you in advance.
    Apr 23, 2012 4:35 PM   in reply to espi62
    If you don't fancy writing one yourself, you could try http://www.xml-sitemaps.com/ to generate one for you.
    As far as I am aware, Dreamweaver has no functionality to create sitemaps.
    Apr 23, 2012 6:04 PM   in reply to espi62
    Dreamweaver had a visual site map function for many years. May not be what you're looking for though.
    It was disabled in CS4 (not sure why).
    You can re-enable the Site Map following instructions from this thread:
    http://forums.adobe.com/thread/317212
    Mac:
    1. Go to your user folder > Library > Preferences 2. Open “Adobe Dreamweaver CS4 Prefs” in a Texteditor 3. Search for sitemap 4. Replace FALSE with TRUE 5. Save the file, restart DW
    Windows:
    1. Click on start
    2. Select Run
    3. Type regedit and click ok
       -> the registry opens now
    1. Select HKEY_CURRENT_USER > Software > Adobe > Dreamweaver CS4 > Feature Management 5. In the right part of the window double click on Site map 6. Set Site map to True
        -> When you restart DW the site map is enabled again
    The feature is no longer supported by Dreamweaver. Use with care at your own risk.
