ElaineC3
Cannot use distiller X to print word to PDF
Apr 23, 2012 7:29 PM
Tags: #acrobat #word #distiller #courier
I cannot use distiller X to print word to PDF.
It always show below error:
%%[ Error: invalidfont; OffendingCommand: findfont ]%%
Stack:
/Font
(Courier)
/courier
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
I have installed acrobat 10 pro in window 7
Also I have install Extensis suitcase 3 in the same PC.
How can solve this problem?
    Apr 23, 2012 7:40 PM   in reply to ElaineC3
    It appears Courier font is not available to all requisite applications.
    You may want to install/reinstall the font and have the OS perfom its process to make the font available.
    Be well...
    Jul 6, 2012 10:06 AM   in reply to ElaineC3
    Having the same issue on XP with Suitcase 3. Even tried epanding & renamiing os fonts from XP to win\fonts, no luck. Still working if its a Windows font thing, Acrobat thing, or Suitcase,.......
    Jul 6, 2012 10:26 AM   in reply to HBAquaman
    Acrobat comes with some fonts. You need them, and need to make sure Suitcase doesn't try to manage them. They probably will be in Adobe folders NOT in Windows folders. (Though the Fonts control panel shows all installed fonts as being in Windows, even if they are somewhere else!)
    Jul 6, 2012 3:12 PM   in reply to Test Screen Name
    Thank you, sent on the right path.
    I reinstalled fonts from control panel-fonts and pointed to the local drive
    C:\Program Files\Adobe\Acrobat 10.0\Resource\Font
    C:\Program Files\Common Files\Adobe\Fonts
    They will still there, but now windows knows it, again.
    that did the trick
    Thanks again
