JedRobinson10
The estimated project size is larger than the target media chosen
Apr 22, 2012 4:33 PM
Tags: #settings #premiere_cs5 #encore #transcoding #larger_than_the_target_media_chosen #mpeg_2 #adobe_encoder
I am at a loss for trying to author a project using Adobe Encore.  I first tried to author the project using version CS2.  When attempting to export I received the following message:
"The estimated project size is larger than the target media chosen.  While this is an estimate, the project may fail to build."
I have authored hundereds of projects in the past, but have never received that message before.  I first thought that the problem was with the version of Encore I was using, but I received the exact same error when trying to author the project with Encore CS5.
The project itself has one menu, a motion menu, and one video file.  The video file last 152 minutes, and I was attempting to export that to a dual layer DVD.  I have since tried exporting the file using Adobe Premier CS5.5 using a variety of settings.  I am trying to export it to a DVD-2 file, with the match soure attributes being set to the highest setting.  The setting on the main concept MPEG encoder is set to 5. I have tried exporting the file using both constant and varaible bit rates.
When I recently exported the file using a contant bit rate of 6.5, I still had 650.4 MB remaining on my Encore project.  I still received the same error about the project size, and so I am thinking that something else is wrong.
I have even exported the video file as an uncompressed AVI file, and then tried encoding it again using both Adobe Premier CS5.5 and the Adobe Encoder.  I still get the same error message about file size.
Any help and/or suggestions about how to solve this problem would be greatly appreciated.  Thanks!
    Apr 22, 2012 6:41 PM   in reply to JedRobinson10
    For dual layer you MUST Run as Administrator http://forums.adobe.com/thread/771202
    -Set to always "run as" via icon http://forums.adobe.com/thread/969395
    Apr 23, 2012 7:19 PM   in reply to JedRobinson10
    Any ROM content?
    How many seconds is the motion menu?
    Are you sure it is 650 MB left (almost a gig) and not 650 KB?
    Apr 24, 2012 5:49 AM   in reply to JedRobinson10
    What happens if you ignore the warning and build?
    I wonder about a layer break issue. Is the main movie a single file?
    None of that should matter, but it often does, but not necessarily with this warning.
    Apr 24, 2012 8:05 AM   in reply to JedRobinson10
    So you don't end up with wasted discs...
    Create an ISO (Encore) or folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
    Imgburn will read the ACTUAL disc brand from the disc, which is not always the same as the box label (Memorex is notorious for buying "anything" and putting it inside a Memorex box)
    When you write to disc with Imgburn, use the SLOWEST possible speed setting, so your burner has the best chance to create "good, well formed" laser burn holes... since no DVD player is required to read a burned disc, having a "good" one from a high quality blank will help
    Use Taiyo Yuden single layer or Verbatim Two layer
    Or Falcon Pro for inkjet printable Two layer
