Hi Everyone,
I'm having a small problem which I do not understand. I have one template with a main navigation drop down menu applied to multiple pages. The secondary drop down menu only works on some pages's but not all. I compared the html, css, scripts and they are all exactly the same when the pages load. Has anyone else experienced this bug when using v2 dynamic menus. I have not experienced this with my other sites.
Thank you,
Chris
Hello VillageBCS,
Is there any way we can get a link to an example of your problem. I've been using the v2 dynamic menus and have not has such an issue.
Chad Smith | www.bcgurus.com/Business-Catalyst-Templates for only $7
Hi Chad, The site I'm having trouble with is not live and the pages are within a secure zone.
I will contact you tonight using my bcgurus pro access.
Thank you,
Chris Lewis
Have you made sure your scripts and images all start with a / in the src?
E.G.
<link rel="stylesheet" href="/css/styes.css" type="text/css" media="screen" />
Yes all of the scripts are using a / in the links.
Thank you for the reply,
Chris Lewis
At a guess then from the info it would likely be a selected state css issue as thats added the parent li or length of the words on menu item causing issues.
Like Chad said, hard to know withougt seeingit. If BC Gurus do not get back to you or solve it drop a PM to me here to look at for you. Hoepfully Chad can sort you out though
