FMS on Amazon Web Services License. Does it need enter License(Serial Key)?
Apr 23, 2012 2:46 AM
Tags: #license #fms #serial_key #aws #activation_key #amazon_web_services
After Subscribe on adobe.com(Adobe Flash Media Server 4.5 on Amazon Web Services)
I build the Amazon EC2 successfully.
In amazonpayments, the amazon show me an Activation Key.
On  Application Activation:
The screen give me following information.
Generate an Amazon Activation Key
An activation key may be required as part of an application's registration process. If your application requires it, follow the steps below:
Step 1: Click on the Generate Key link to generate an activation key for an application.
Step 2: Copy the activation key.
Step 3: Click on Go to Application to access the application.
Step 4: Paste the activation key if and where the application specifies.
But in Adobe Flash Media Administration console, It is missing the License(Serial Key)
How can I use the  Activation Key?
    Apr 23, 2012 11:58 PM   in reply to CallMeNSon
    This Activation Key is only for identification purposes. In most cases, you will not have to use it. Once you subscribe to FMS on AWS, you are ready to go and use FMS AMI's.
    Also, FMS on AWS does NOT require any License or Key. It works on a separate Licensing model.
