ratbch
.pdf files won't open in Internet Explorer 9 after adobe 10.1.3 update
Apr 18, 2012 6:16 PM
I have re-installed Adobe 10.1.3 several times and I cannot view, open, or save .pdf files.  I tried using Safari and can view and save .pdf files, but I use Int. Explorer 100% of the time.  What is the fix?
    Apr 20, 2012 3:16 PM   in reply to ratbch
    Be sure you are using the 32 bit IE9, not the 64 bit.
    Apr 24, 2012 3:34 AM   in reply to ratbch
    Hi ratbch,
    What os are you using?
    Do you have safari and IE9 on the same system?
    Please try using IE9 in 32-bit mode.
    Apr 24, 2012 7:26 AM   in reply to ratbch
    Hi ratbch,
    Is the issue with only Internet explorer or are you not able to view PDF's in Adobe Reader as well?
    Are you able to open Adobe Reader without opening any PDF ( i.e. from start-> All Programs)  without any issues?
    Also try to open this PDF: http://helpx.adobe.com/content/dam/help/attachments/Acrobat_Reader_Rel easeNote_10.1.3.pdf
    What exactly do you see when you open the PDF in IE9?
    Apr 24, 2012 8:29 AM   in reply to Nikhil.Gupta
    I have the same issue. Opening the PDF you gave works fine, but there's a host of PDF's I can no longer open, and attempting to do so causes the IE9 tab in question to crash. Examples are PDFs served by online Journals. This is on Win7 x64, of course using 32-bit IE9. Clearly the Acrobat update to 10.1.3 has introduced a bug that causes the IE9 crashes. Like the OP, I can open these PDFs fine in other browsers, such as Chrome (which does not use Acrobat, I believe).
    Apr 24, 2012 8:33 AM   in reply to DRempfer
    Please can you share URL of any such PDF that is causing this behavior?
    Apr 24, 2012 11:57 AM   in reply to Nikhil.Gupta
    Unfortunately all of the sites I have found to exhibit this behavior have restricted access. If I can find one that allows free access I'll let you know.
    Apr 24, 2012 3:04 PM   in reply to Nikhil.Gupta
    Try this one:  http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3226614/?tool=pubmed
    there is a link for the pdf in the top right corner.  I'm running OS 10.6.8, Chrome 18.0.1025.163 and Reader 10.1.3.  The problem occurred on the update to reader.  When I go to preferences-> Internet in Reader "Display PDF in browser using..." is greyed out.
    Trying to follow that link in Chrome (or Firefox) gives me either a black screen or a plugin not found error.  Can open them fine with Chrome's built in PDF reader but would much prefer to use Reader for various reasons.
    Thanks.
    Apr 24, 2012 5:51 PM   in reply to Cheeseboy999
    For what it's worth, I can open this link fine in IE9 on Win7x64.
    Apr 25, 2012 2:33 AM   in reply to ratbch
    Hi ratbch and Drempfer,
    As you have stated that you are successfully able to open the PDF whose link I had provided and are not able to open other PDF's, the issue seems to be specific to kind of PDF's.
    Just to figure out what it could be please try to save these pdf's on your system and then try to open them directly into Reader.
    What happens when you do so, also please state what exactly happened when you opened them in IE9.
    Also it is essential that you share this kind of PDF so that we can figure out the issue.
    Nikhil
    Apr 25, 2012 3:09 AM   in reply to Cheeseboy999
    Hi Cheeseboy999,
    I think opening PDF in Firefox using 32-bit mode should solve your problem on MAC.
    May 1, 2012 11:18 AM   in reply to ratbch
    I ran into the same problem this morning with Acrobat X Pro v10.1.3, IE9 (32-bit) & Windows 7 Pro.  I found that I could access PDFs on www.irs.gov, but I could not open PDFs that were set to download (as opposed to opening them within the browser).
    What I did
    1). Open Acrobat
    2). Select "Repair Acrobat Installation" from the Help menu
    3). Rebooted as instructed after it completed its repair
    I now have no problems opening any PDFs through IE9.
    May 10, 2012 8:35 PM   in reply to Nikhil.Gupta
    Apologies for the late reply.  It does work in Firefox but would much prefer to use Chrome as I find Firefox quite slow.  Is there any plans for Adobe to fix the Chrome extension as it worked fine before the reader update?  Thanks.
    May 11, 2012 3:09 AM   in reply to Cheeseboy999
    Hi Cheeseboy999,
    Please check if the Adobe PDF plug-in is enabled. To do same type chrome://plugins/ in your browser.
    May 11, 2012 9:20 AM   in reply to Nikhil.Gupta
    This is what I have (with an option to Disable it underneath)...
    Adobe Acrobat NPAPI Plug-in, Version 10.1.3 - Version: 10.1.3
    Adobe® Acrobat® Plug-in for Web Browsers, Version 10.1.3
    When I open a pdf I get a black screen saying Missing Plugin.
    Jun 28, 2012 5:46 PM   in reply to SundryTech
    Didnt work for me. But what did work for me was changing Acrobat so that it does not open the PDF in the browser.With thanks to Amanda on the Microsoft web site, see http://answers.microsoft.com/en-us/ie/forum/ie8-windows_vista/cannot-o pen-pdf-files-in-internet-explorer-8/730af0e4-a10b-4402-8953-7318046de 0ac
    Found this answer buried deep on a website - and it works!!
    Configuring the browser to open PDF files in an Acrobat window
    If you want the browser to open PDF files in a separate Acrobat window, then configure the browser to use Acrobat or Adobe Reader as a helper application. Then, when you select a PDF file in Internet Explorer or AOL, the browser opens the PDF file in an Acrobat window instead of the browser window.
    To configure the browser to use Acrobat or Adobe Reader to open PDF files:
    1. Close your web browser.
    2. Start Acrobat or Adobe Reader.
    3. Choose Edit > Preferences.
    4. Select Internet in the list on the left.
    5. Deselect Display PDF in Browser, and click OK.
    6. Restart Internet Explorer or AOL.
    Note:The next time you select a link to a PDF file, the browser may prompt you to open or save the file. If you choose to open the file, then the browser opens the file in the helper application that you specified. If you choose to save the file, then the browser downloads the file to the hard disk.
    For more information about the general preferences in Acrobat or Acrobat Reader, refer to the Acrobat Help.
    Jul 10, 2012 1:43 PM   in reply to PeterM81
    I am in trouble here myself. I have Vista Home Edition 64 bit.The world was all good until I allowed this update to proceed. I cannot revert to the old (working) version of Adobe because one of the suggestions was to uninstall it which I did.
    I have checked to make sure I was using 32 bit browser mode and not 64
    Installed/Reinstalled/Repaired Adobe [This installation was a nightmare taking up several hours of troubleshooting]
    I changed the settings in Adobe as above and rebooted everything
    I can open PDF files on my hard drive.
    I can open PDF files on http sites
    I CANNOT open or download PDF files on https sites anymore (though I could before the upgrade)
    ****Of course THOSE are the ones I really really need since I am paperless with the bank, verizon, etc etc.....I tried today going to all the same sites on my IE8,XP work computer with Adobe Reader 9 and viola! no issues. They all work as expected
    I elected NOT to run Chrome as it gave me issues before. I only use one browser IE9 and it is Version 9.0.8112.16421 update version 9.0.7 and my windows updater only shows nonrelated optional upgrades available, one of which is silverlight that I have not installed.
    Please Advise!
    EDITED - I took a browser test on Wells Fargo and it said I was on IE7. I went to compatiblity settings unchecked the run all that way (I don't think I did turn that on) but it still says I am on IE8 even though I am on IE9 and IE9 says so--somehow I think that may be part of the issue. FWIW I had now problem downloading their "test" PDF file but it was on the unsecure section of their site.
    LAST EDIT - Not sure why this did not happen before but maybe it was an IE9 Update - If you to go Tools>Internet Options>Advanced and scroll to the bottom there is a check box for "Do not save encrypted files to disk" that Microsoft thought needed to be checked. However, if the file is encyrpted and the block is checked you can neither see it or download it. Worked like a charm when that block is unchecked. So nothing to do with Adobe, all to do with IE9.
    Message was edited by: jocoyn
    Calculating status...
    Aug 29, 2012 3:51 PM   in reply to PeterM81
    I wasted hours and this was such a simple fix.  Of course it too is now getting buried.
    Oct 15, 2012 12:05 PM   in reply to Nikhil.Gupta
    I have no answer. I can't seem to open any pdf file in IE9. IE 9 closes the program.
    Most computer users don't know how to change which IE 9 they are using.
    Here is a pdf file that can't open:
    http://www.lifeway.com/lwc/files/lwcF_PDF_Hamilton_DesignatedFundManag ement.pdf
    Oct 15, 2012 8:52 PM   in reply to dashep100@
    I have no problem opening that file (IE9 32-bit on Windows 7 x64, using Adobe Reader XI).
    What exactly happens when you are trying to open it?  (Using what configuration?)
