Hi All!
I'm struggling to figure out Dreamweaver's syntax for a Recordset I'm building. I'm using Dreamweaver 8, ColdFusion 9 to connect with my database, and Windows 7.
I have to start by admitting I copied code from an similar program, and am trying to get it to work for me.
Here's the error I get when I "test" the recordset:
Syntax error. in query expression '1=1
Here's the query:
SELECT LastName, FirstName, MiddleName, Generation, PartyType
FROM [Party Information]
WHERE 1=1
SELECT FullCaseNo, DocketSheet
FROM [Case Information]
WHERE 1=1
<cfif IsDefined("Form.LastName") and Form.LastName NEQ "">
AND PartyInformation.Last Like'#Form.LastName#%'
</cfif>
<cfif IsDefined("Form.FirstName") and Form.FirstName NEQ "">
AND PartyInformation.First Like'#Form.FirstName#%'
</cfif>
<cfif IsDefined("Form.CaseNo") and Form.CaseNo NEQ "">
AND CaseInformation.FullCaseNo ='#Form.CaseNo#'
</cfif>
ORDER BY LastName, FirstName, MiddleName, FullCaseNo
For the sake of just seeing I deleted "WHERE 1=1" just to see if it would run, and I got another syntax error in the FROM clause. In case this wasn't already obvious I'm brand new to Dreamweaver and just trying to get this thing to work.
Any help is much appreciated, thanks in advance!!
Definitely!
I have two pages, a query page where a user can search a database of old
court records by LastName, FirstName, or CaseNumber. The results are then
displayed in a results page sorted by LastName. I want the query to take
the inputs, and go find any matching records and return all information
related to those records.
Does that answer your question?
I just spoke with my supervisor, and unfortunately I can't do that because
of the security surrounding the Court. That said, through the discussion I
found out that this project might be dissolved tomorrow after a conference
call. It's unfortunate I'm the last to know, considering I'm the one doing
the project. So sorry to have taken up your time. Thanks for trying to
help!
I don't use ColdFusion, but your SQL query doesn't make sense. For example, your table names are [Party Information] and [Case Information]. Normally square brackets and spaces should not be allowed in database table names, unless that's the CF way of escaping names with spaces.
Even so, the WHERE clauses use PartyInformation and CaseInformation. Also, the column names are different. In the SELECT clause, you use FirstName and LastName, but the WHERE clauses use First and Last.
Finally, I suspect that you need to use LEFT JOIN. So, the beginning of the query would look like this:
SELECT LastName, FirstName, MiddleName, Generation, PartyType, FullCaseNo, DocketSheet
FROM PartyInformation LEFT JOIN CaseInformation
WHERE 1=1
That's sad to hear.
Anyway, if you're continuing to work on this, why dont you try replacing this:
WHERE 1=1
with this:
WHERE 0=1
WHERE 1=1 is usually a SQL code to prevent injections and to increase performance of the query you're running.
WHERE 0=1 will usually look up all records in the table you're querying into - this is what you're trying to achieve here anyway.
and rename the table on your DB from Party Information to PartyInformation
