I'm trying to automate generation of PDF in FrameMaker 10 and WebHelp from the same source in RoboHelp 9.
I have two scripts that are working, now I'm trying to run them as a single script.
Looking at a discussion about InDesign scripting (http://forums.adobe.com/thread/776832), I thought maybe the following would work:
robohelp.executeScriptFile("c:\\Users\\rlauriston\\Documents\\help_automation\\2_robohelp.jsx")
but when I debug it in ExtendScript Toolkit CS5.5, I get "robohelp is undefined".
Reading Adobe Creative Suite 5 JavaScript Tools Guide, I get the impression that this should work:
robohelp.executescript(
var projectPath = "C:\\Users\\rlauriston\\Documents\\My RoboHelp Projects\\AG\\SentrionAdminGuide.xpj";
main();
function main()
if(projectPath == "")
//Error!. Quit RoboHelp
alert("Project path is not defined. \nPlease update the 'projectPath' variable in the script.");
RoboHelp.quit();
RoboHelp.openProject(projectPath); //Open the project
RoboHelp.project.updateAll(true); //Update all linked documents (pass true for Force update)
RoboHelp.closeProject(); //Close project
RoboHelp.quit(); //Quit RoboHelp
but when I debug it I get "Illegal use of reserved word 'var'". If I move the var declaration to the top of the file, I get "Expected: )" on the semicolon after main().
For working with fileObj, you first need to create a file object.
//Create bat file object
var mybat = new File(“C:/mybatfile.bat”);
//Create content
var content = “\ndel /F /! \”” + mybat.fsName + “\””;
//Write content to bat file
mybat.open(“w”);//This will open for writing and create if not exists
mybat.write(content);
mybat.close();
//Run the bat file
mybat.execute();
If you want more examples, check the ePub generation script in RoboHelp 9. That uses the function writeFile (if I’m not mistake
...Copy link to clipboard
As far as I can make out, everything after robohelp.executescript is considered an argument for the function executescript. Opening RoboHelp and run a script, see http://help.adobe.com/en_US/robohelp/robohtml/WS98613C7C-EF5B-48e9-A91A-D2AABB882687.html
For running both applications from a single script, I’ve been told you can use the Bridge features. But I’ve never seen an example of that.
Greet,
Willam
There's no framemaker.exe -x [scriptfilenames], is there?
Odd that there's no sample code, given how much time and effort Adobe clearly put into creating and sort-of documenting those cross-application features.
I have absolutely no idea as I haven’t used FM scripting. You will probably have better luck asking this on the FM forum: http://forums.adobe.com/community/framemaker
But you could write a script you run in framemaker that starts RoboHelp with the script you want to run.
Greet,
Willam
Thanks. I already asked that question over there, but maybe it was buried in a more general question. I asked again: http://forums.adobe.com/thread/992890
"... you could write a script you run in framemaker that starts RoboHelp with the script you want to run."
Is there a sample script somewhere that does that? I haven't been able to find one.
Not that I know. But I was thinking along the lines of running the script in FM, then writing a batch file in ExtendScript that launches RH and the script that should be run.
Greet,
Willam
I've got the two scripts, and I could use robohelp -x <script> to launch the second one, but I can't figure out how to chain them.
In the Creative Suite 5 JavaScript Tools Guide, it says that fileObj.execute() "Opens this file using the appropriate application, as if it had been double-clicked in a file browser. You can use this method to run scripts, launch applications, and so on." So it ought to be possible to have the FrameMaker script start a batch file that launches the RoboHelp script, but I can't find a sample script that does that, nor can I figure out from the documentation how to specify fileObj.
Also, using the ExtendScript Toolkit CS5.5 Object Model Viewer, I can't find an execute() function.
//Create content
mybat.close();
//Run the bat file
mybat.execute();
If you want more examples, check the ePub generation script in RoboHelp 9. That uses the function writeFile (if I’m not mistaken) to write to a file.
Greet,
Willam
Thanks! This works:
var myfile = new File("C:\\test\\test.bat");
var content = "C:\\Progra~2\\Adobe\\adober~1\\RoboHTML\\robohtml -x C:\\test\\2_robohelp.jsx";
myfile.open("w");
myfile.write(content);
myfile.close();
myfile.execute();
Now I get it. fileObj is the object type to use when setting a variable to a file. If the batch file c:\test\test.bat already exists, all I need is:
myfile.execute();
Indeed.when the file exists you can skip the step. But you have to be sure that the bat file contains the correct commands.
Greet,
Willam
Yes, and for a script that was going to be reused in various contexts generating the batch file might be a better choice. In this case, I already had the batch file working, and it contains additional commands that are executed after the RoboHelp script.
