Using Acrobat Pro how do I lock the fillable fields once the data is collected?
Avatar
Level 1
Avatar
Level 10
Have a look at Paul's LockAllFields solution. You can download it in Paul's post here: http://forums.adobe.com/message/3168183#3168183.
I have a version of it here as well: http://assure.ly/yDtfsM.
Hope that helps,
Niall
Avatar
Level 1
Ok I see it but how do I copy it into my form? Or do I need to write a script for it?
Also should I be using LiveCycle instead of Acrobat Pro for this function?
Avatar
Level 10
Hmmm...
Did you create the form in LiveCycle Designer (XFA Forms)? Or in Acrobat (AcroForms)?
The solution I posted is for forms created in LiveCycle Designer.
You will be able to lock fields in AcroForms, but I think you would need to target each field individually (eg a different solution to the one posted). If you have created your form in Acrobat, you may get better advice on the Acrobat forums.
Hope that helps,
Niall
