tweaking FM_Outputs_Conditional_Text.jsx
Apr 24, 2012 11:15 AM
I found what sees like a bug in C:\Program Files (x86)\Adobe\AdobeFrameMaker10\Samples\ScriptsAndUtilities\Conditional Text\FM_Outputs_Conditional_Text.jsx.
The script produces two PDFs, which I expected to be named <book_name>_Comment_Red.pdf and <book_name>_Blue_Green.pdf.
Instead, they're named <book_name>.book_Comment_Red.pdf and <book_name>.book_Blue_Green.pdf.
The relevant lines seem to be:
FileSource = OpenBook(InputFile);
SavePdf(FileSource,InputFile + OutPutFiles[output_no]);
Is there some way to tweak the second line so as to remove the .book extension from FIleSource? Or to define another variable minus the extension?
    Apr 24, 2012 11:23 AM   in reply to rlauriston
    Assuming that InputFile is the path to the book, you can use this:
    SavePdf(FileSource,InputFile.replace(/\.book$/i,"") + OutPutFiles[output_no]);
    I haven't tested it, but it should work. It replaces the .book extension with an empty string.
    Rick
    Apr 24, 2012 12:09 PM   in reply to rlauriston
    This is standard JavaScript regular expressions syntax.
