Hi, first came across this problem here...
http://forums.adobe.com/thread/797819
But there was no solution offered except to disable some security settings. As this issue was in feb last year, i am wondering if Adobe has the solution as i recently encountered the same problem on Acrobat X Pro.
Please advise.
I am trying to save to my the default documents folder but the acrobat says you can only save in my own personal documents folder. There is a trendmicro virus scan running but I do not think it is a problem as we had no problem with Adobe Acrobat X version that came with CS5.
We were trying to do a file > print > print to adobe PDF.
The problem isn’t so much of the function as if we save the pdf to personal folder, it still appears there. But the problem is that the user then has to drag the file over manually to the default folder.
I doubt it is an issue with the OS or IE as this problem only surfaced recently when we upgraded from a master suite 5.0 CLA to a master suite CS 5.5 ELA version.
I had this problem with Adobe Acrobat X on my Windows 7 system using IE9. (Note that I did not receive this error in Firefox as others have also reported in other forum posts.) I spoke with a guy in Adobe support who recommended this solution...
That's it!
Finally, when you install Acrobat it should also install an Adobe Add-On in Internet Explorer. It adds a two buttons ("Convert" and "Select") to the IE toolbar area. The Adobe tech recommended using the "Convert" button rather than just printing to a PDF as it "prints more accurately". Note that selecting the drop down arrow you can choose other options like, "Convert Web Page and E-mail".
I hope this helps others.
