Under attributes, I choose "Polygon" as the image map shape. When I export the file, the imagemap option is set to Client-side (.htm
l). It creates the html but in the html source code, the shape has been set to "rect" not "poly" and the coordinates are for a recta
ngle, not a polygon. The polygon option in attributes does not appear to be working. Is there something else that needs to be done?
Operating System: Windows XP Professional
Illustrator CS4
You might nit like this response and I do not know if this is a bug or the way it was designed but the good news is you can do what you want but…you have ti use save for device and web and if you need top quality use the original from save for the device and web rather than one of the optimized versions.
Although file size and loading time would be better with an optimized version.
This will work even if it is not quite what you want.
