designmon79
Tagging for Character Style
Apr 17, 2012 5:34 AM
Hi All,
Need to insert tagging (character style name) surrounding the text which has character styles applied in InDesign document.
Example: This is <italic>an</italic> example of <bold>character style</bold> tagging text.
Please provide JS code for this.
Thanks in advance,
Mon
    Apr 23, 2012 5:15 AM   in reply to designmon79
    I think a simple grep find/change will work, look at the image below.
    The .+ finds any character, one or more times,
    In the Change To field type the code you want to use eg <bold>$0</bold>, the $0 puts back what is found.
    Finally, in the Find Format area, select the formating that you are looking for.
    Apr 23, 2012 6:57 AM   in reply to designmon79
    > But I need Javascript code for this
    Virtually demanding a script rarely helps. Maybe you should ask someone if they were willing to write the code for you. And if you offer to pay something for it I'm sure someone will sort you out.
    Peter
    Apr 24, 2012 9:10 AM   in reply to designmon79
    Apr 24, 2012 10:52 PM   in reply to designmon79
        Try this. I'm also fresher...
    First u have to create tags manually with names b, bi,i, sc (bold,bolditalic,italic, small caps)...
    then execute this js...
    docObj=app.activeDocument;
    xmlObj = docObj.xmlTags;
    pageObj=docObj.pages.item(0);
    myTextFrame=pageObj.textFrames.item(0);
    myText=myTextFrame.parentStory.paragraphs.item(0);
    app.findTextPreferences = app.changeTextPreferences =  NothingEnum.nothing;
    app.findTextPreferences.fontStyle = "Bold";
    app.changeTextPreferences.markupTag=xmlObj[0].name;
    alert(app.changeTextPreferences.markupTag);
    app.activeDocument.changeText();
    app.findTextPreferences.fontStyle = "Bold Italic";
    app.changeTextPreferences.markupTag=xmlObj[1].name;
    app.findTextPreferences.fontStyle = "Italic";
    app.changeTextPreferences.markupTag=xmlObj[2].name;
    app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
    app.findGrepPreferences.capitalization = Capitalization.SMALL_CAPS;
    app.changeGrepPreferences.markupTag=xmlObj[4].name;
    alert(app.changeGrepPreferences.markupTag);
    app.activeDocument.changeGrep();
    Apr 25, 2012 12:00 AM   in reply to designmon79
    Hi mon,
    I can't get ur question clearly. Please tell me with an simple example.
    Thanks & Regards,
    Vel.
    Apr 25, 2012 1:29 AM   in reply to designmon79
    < and > appear because you put them there. Instead of
    app.changeGrepPreferences.changeTo = "<$0>"
    use
    app.changeGrepPreferences.changeTo = "$0"
    Peter
    Apr 25, 2012 1:40 AM   in reply to Peter Kahrel
    I also think to say the same thing as said by peter. But u expecting the same thing mon?
    Apr 25, 2012 3:35 AM   in reply to designmon79
    Try this:
    styleCodes = ['Bold', 'Italic', 'Bold Italic'];
    styleTags = ['bold', 'italic', 'boldItalic'];
    app.findGrepPreferences = app.changeGrepPreferences = null;
    app.findGrepPreferences.findWhat = '.+';
    for (i = 0; i < styleCodes.length; i++)
        app.findGrepPreferences.fontStyle = styleCodes[i];
        app.changeGrepPreferences.changeTo = '<'+styleTags[i]+'>$0<' + '/' + styleTags[i] + '>';
    Peter
    Apr 25, 2012 4:57 AM   in reply to designmon79
    True, that's what you wanted:
    charStyles = app.activeDocument.allCharacterStyles;
    // Start at 1 to skip charstyle [None]
    for (i = 1; i < charStyles.length; i++)
        app.findGrepPreferences.appliedCharacterStyle = charStyles[i];
        app.changeGrepPreferences.changeTo = '<'+charStyles[i].name+'>$0<' + '/' + charStyles[i].name + '>';
    Peter
