I'm doing some webstuff in Flash CS5 using actionscript 3, and I could use some help with a couple of things. Can anyone recommend some tutorials on how to make an effective image gallery? Like with a picture slider or something? But ideally nothing overly complicated to do. I don't wanna just copy and paste code off of a website either, I wanna know how to actually make the code using Flash...maybe even just using the snippets if that's doable.
I'd also like to find a tutorial that'll teach me how to make a scroll bar so I can scan up and down text or images for another part of the project.
I'm looking for either video tutorials or written tutorials.
I've been googling like a mad man. Managed to find some help with the gallery but not having a lot of luck with the scroll bar. I've found some from older versions of flash that seem to be just different enough to confuse me when I try to do them in cs5.5 lol. Can anybody give me any advice on scrollbars? I'm having trouble even getting the preset scrollbar in the components to work properly which I imagine is supposed to be pretty simple.
thanks
http://theflashconnection.com/book/export/html/186 go through this link you can find vertical custom scroll bar making.
I can take a stab at that tutorial from Flash connection but if anyone has advice a REALLY simple tutorial or even advice on how to make one themselves that'd be great. I went through this tutorial yesterday: http://www.schoolofflash.com/2011/05/smooth-scrollbar-flash-tutorial/
It seems really simple and straight forward and I'm still getting errors from it and can't figure out what I'm doing wrong...kinda banging my head agains the wall at this point.
I just thought of something. That tutorial I mentioned in the above post...I've followed everything exactly as far as I can tell...I solve a couple problems along the way and no longer get any compiler errors, but when I render to an swf the scrollbar isn't functional and I get this message in the output
TypeError: Error #1010: A term is undefined and has no properties.
at scrollbar_fla::scrollbar_46/frame1()
at flash.display::MovieClip/gotoAndPlay()
at scrollbar_fla::MainTimeline/fl_ClickToGoToAndPlayFromFrame_5()
I'm pretty new to actionscript so maybe this is pointing me to an easy fix that I'm just not recognizing...does anybody have any suggestions based on this kinda of error? The scrollbar I made is inside a movie clip that stops on frame 46...so presumably that's why the number 46 appears in the error?
You can create mask for the movieclip as exactly as in your tutorial. and use below code (I think this is what you want).
For using the below code you should create some user defined components.
For Horizontal Scroll Bar: create hscrollBG for scrollbar background and hscroller for scroller.
For Vertical Scroll Bar: create vscrollBG for scrollbar background and vscroller for scroller.
mask_mc is mask movieclip and content_mc is which the content you want to scroll.
/**** code ****/
var hscrollbar:MovieClip;
var vscrollbar:MovieClip;
if (content_mc.height > mask_mc.height)
drawVScrollBar();
if(content_mc.width > mask_mc.width)
drawHScrollBar();
private function drawVScrollBar():void
try
removeChild(vscrollbar);
catch (e:Error)
vscrollbar = new MovieClip();
addChild(vscrollbar);
vscrollbar.x = mask_mc.width + 5; //set scrollbar position
var bg:vscrollBG = new vscrollBG();
bg.height = mask_mc.height;
vscrollbar.addChildAt(bg,0);
var scroller:vscroller = new vscroller();
scroller.x = 1;
scroller.y = 0;
vscrollbar.addChildAt(scroller,1);
scroller.addEventListener(MouseEvent.MOUSE_UP, sc_mouseup);
scroller.addEventListener(MouseEvent.MOUSE_DOWN, sc_mousedown);
stage.addEventListener(MouseEvent.MOUSE_UP, sc_mouseup);
private function sc_mousedown(e:MouseEvent):void
var scroller:MovieClip = vscrollbar.getChildAt(1) as MovieClip;
scroller.startDrag(false, new Rectangle(1, 0, 0,mask_mc.height- scroller.height));
scroller.addEventListener(Event.ENTER_FRAME, updateScrollPosition);
private function sc_mouseup(e:MouseEvent):void
stopDrag();
scroller.removeEventListener(Event.ENTER_FRAME, updateScrollPosition);
private function updateScrollPosition(e:Event):void {
var bg:MovieClip = vscrollbar.getChildAt(0) as MovieClip;
var perc:Number = scroller.y * 100 / (bg.height-scroller.height);
var ypos:Number = ( -perc * ((content_mc.height - mask_mc.height) / 100));
content_mc.y = ypos;
private function drawHScrollBar():void
try
removeChild(hscrollbar);
catch (e:Error)
hscrollbar = new MovieClip();
addChild(hscrollbar);
hscrollbar.y = mask_mc.height + 5;
var bg:hscrollBG = new hscrollBG();
bg.width = mask_mc.width;
hscrollbar.addChildAt(bg,0);
var scroller:hscroller = new hscroller();
scroller.x = 1;
scroller.y = 0;
hscrollbar.addChildAt(scroller,1);
scroller.addEventListener(MouseEvent.MOUSE_UP, hsc_mouseup);
scroller.addEventListener(MouseEvent.MOUSE_DOWN, hsc_mousedown);
stage.addEventListener(MouseEvent.MOUSE_UP, hsc_mouseup);
private function hsc_mousedown(e:MouseEvent):void
var bg:MovieClip = hscrollbar.getChildAt(0) as MovieClip;
var scroller:MovieClip = hscrollbar.getChildAt(1) as MovieClip;
scroller.startDrag(false, new Rectangle(bg.x, bg.y, bg.width - scroller.width,0));
scroller.addEventListener(Event.ENTER_FRAME, hupdateScrollPosition);
private function hsc_mouseup(e:MouseEvent):void
stopDrag();
scroller.removeEventListener(Event.ENTER_FRAME, hupdateScrollPosition);
private function hupdateScrollPosition(e:Event):void {
var perc:Number = (scroller.x - bg.x) / (bg.width - scroller.width);
var xcounter:Number = ( -perc * (content_mc.width - mask_mc.width));
content_mc.x = xcounter;
This code is reusable for many applications where we want scrollbar. In this code we can dynamically assign the scrollbars based on the content width and height.
