Thanks so much (Stephen_Fedder), your solution did work for me even so I got an "encore osstatus error = -54". I eventually had to delete the entire indexed directory to get it to work properly. I deactivated indexing of my video editing HD to avoid further problems of the sort.
ps. : problem doesn't seam to be fixed in CS5 either so I will still be working on my old CS3 since the updates are so expansive and the errors are not fixed.
Thank you Stephen_Fedder for your info about Spotless. However, when i choose "Disable Spotlight" in the program, I get the following warning: "When you disable Spotlight, all existing Mac OS X 10.5 content indexes will be deleted from all attached volumes. You will no longer be able to perform searches in any application that supports Spotlight searching."
As this would be on my main computer, and with previous computer problems and loss in mind, I can feel I face some fear of doing something wrong here. Could you please confirm I am on the right track, or should I choose "disable indexing" in stead?
Thank you,
Johnny
>DVD was able to burn in admin profile
You are Mac, I am Windows... so I do not know "exactly" how encore works for you
But... in Windows... Encore MUST be run with an Admin account... and, for dual layer, the added step of actually using the Run as Administrator option MUST be used
So... I will guess things are similar over in the Mac world
Run as Administrator http://forums.adobe.com/thread/771202
-Set to always "run as" via icon http://forums.adobe.com/thread/969395
Thank you Stephen for your info about Spotless, which I downloaded. However, when i choose "Disable Spotlight" in the program, I get the following warning: "When you disable Spotlight, all existing Mac OS X 10.5 content indexes will be deleted from all attached volumes. You will no longer be able to perform searches in any application that supports Spotlight searching."
As this would be on my main computer, and with previous computer problems and loss in mind, I can feel I face some fear of doing something wrong here. Could you please confirm I am on the right track, or should I choose "disable indexing" in stead? I am using Encore CS3.
Maybe it´s because I use a Mac, and maybe it´s due to me using CS3, but I get no respond when I right click the Encore Icon (before I start the program?) , and when in Encore,
I can´t find any option to select Properties/Advanced/Run as Admin. I´m grateful for any help, as I have not been able to finish my work here. A bit odd though, I never had this problem the first times I was exporting to Encore from Premier Pro CS3.
