Iceking007
DVD Autolaunch in computer
Apr 24, 2012 9:13 AM
Tags: #menu #dvd #encore_cs5
I burned my movie to DVD and when I put the disc in it automatically loads the disc and opens the Sub menu/chapter menu once I close that and double click on the DVD it starts the first play and then loads the Main Menu just as it should; so why would it automatically open the  Sub menu when incerted into the DVD drive?
I think this is an auto run .ini problem but not sure if I can fix it with Encore or if I have to edit the disc image myself; have not been able to test it on a DVD machine only computer this happens on two different computers and windows versions.
Any help would be appreciated thank you.
    Apr 24, 2012 9:35 AM   in reply to Iceking007
    Post a screen capture of your navigation flowchart
    This SEEMS as if you have a "first play" set wrong
    Apr 24, 2012 10:16 AM   in reply to Iceking007
    What player is being used for the autorun?
    Apr 25, 2012 6:02 AM   in reply to Iceking007
    I believe WMP was opening the DVD automatically
    Many software players do not emulate naviation correctly. Look and see: what app is opening the DVD automatically? Is it the same app that opens when you then "double click the DVD"?
    Why is the submenu linked twice from menu 1?
    Apr 25, 2012 9:11 AM   in reply to Iceking007
    VLC does often have trouble opening to the Main Menu.
    Test this on a hardware player.  If it works there, you're good.  Not much you can do about software errors.
    Apr 25, 2012 6:24 PM   in reply to Jim Simon
    I agree with Jim that you must test with a burned disk on a hardware player. Software tests can be helpful, but if your navigation is anything other than plain vanilla, you need a better player. Total Media Theater 5 works well for me; others like PowerDVD.
    Apr 26, 2012 8:29 AM   in reply to Iceking007
    I am not 100% sure, but I think http://www.imgburn.com/index.php?act=download allows more than one drive... you would create an ISO or folder in Encore, then use Imgburn for the actual writing process
    Apr 26, 2012 8:58 AM   in reply to John T Smith
    ImgBurn runs multiple instances and recognizes multiple drives. I copy 2 disks at once (same or different source images) at the same time - both internal or one internal and 1 extermal (USB) burner. I haven't tried 3 yet, but I see no reason it won't work.
