XELAD111
Analog of Watch() in AS3
Apr 24, 2012 12:40 PM
Hello everyone!
Here is a situation:
var MAIN_OBJ:Object = new Object();
MAIN_OBJ.array_1 = new Array(1, 2, 3);
MAIN_OBJ.array_2 = new Array(A, B, C, D, E, [f,g,h,i,j]);
MAIN_OBJ.array_3 = new Array([k,l,m,n,o,p], Q, R, S, T);
ActionScript2:
function someFunction(prop, oldVal, newVal, limit) { trace("prop is about to change"); return newVal;}
MAIN_OBJ.watch("array_1", someFunction);
ActionScript3:
Use accessor properties (get/set functions) or the flash.utils.Proxy class for similar functionality.
Here is the task:
Watch some property of object to change, and do smth. Watch not the whole object, only one property.
I know that ExternalInterface.addCallback provides smth like that, but for the whole object.
I've never used get/set functions or override smth, please explain what should exactly be written to achieve the same effect as in AS2. The simplier it would be - the better.
Sorry fo my English.
  • kglad
    Jul 21, 2002
    Apr 25, 2012 6:34 AM   in reply to XELAD111
    // in watching class:
    watchedClass.addEventListener("propertyChangedE",propertyChangedF);
    private function propertyChangedF(e:Event):void{
    // do whatever
    // in watched class, dispatch event whenever changed from inside the class and from outside:
    public function set someProperty(someValue:ValueType):void{
    _someProperty=someValue;
    dispatchEvent(new Event("propertyChangedE"));
  • kglad
    Jul 21, 2002
    Apr 25, 2012 10:44 PM   in reply to XELAD111
    again, // in watched class, dispatch event whenever changed from inside the class and from outside:
  • kglad
    Jul 21, 2002
    Apr 27, 2012 8:30 AM   in reply to XELAD111
    it looks like you don't really understand how to use class files.  there are numerous problems with those few lines of code.
    i think you would be better off learning how to crawl before trying to run.  i would recommend studying some of the basics of oop and class file structure.
    so, i'm not sure how much this will help you, but you should use:
    package  {
           import flash.events.EventDispatcher;
              public class Main {
         public var MAIN_OBJ:Object = new Object();
                        public function Main()
    //the line below belongs elsewhere in the class where you want to detect a change
                             //     this.addEventListener("propertyChangedE",propertyChangedF);
                                  MAIN_OBJ.array_1.push(4);
    // dispatch event whenever changed from inside the class:
                        public function set AddArray_1(someValue):void
                                  MAIN_OBJ.array_1.push(someValue);
    //dispatch event whenever changed from outside:
    May 1, 2012 8:54 AM   in reply to XELAD111
    There is no event that will fire off "automagically" when you change a property of an object.
    Read what I said above a few times.
    People here are telling you to make a function to change a property of the object. The reason why is because you can dispatch an event in the same function when you change that property.
    That is the only way you will know when the property changes.
    I'll say it again. Read line 1. There is no event that fires "automagically" when you change a property of an event.
    That is programming 101. You create a "getter" and a "setter" function for the objects properties then you do whatever you want in those functions. For your needs, you want to dispatch an event. So do it, like has been mentioned.
    Leave anything you ever learned in AS2 in the grave, where it belongs.
