Robert Schmitz
How can I attach a PDF in an email, using javascript in PDF document?
Apr 25, 2012 6:26 AM
Tags: #acrobat #mail #javascript #button #form #interactive
How can I attach a PDF in an email, using an interactive button in the PDF-document?
I tried to create a form button with the menu action 'attach this PDF in an email'.
This Send.to-action doesn't work with Microsoft.
Does anyone has a solution by implementing a javascript-code for this in the PDF?
    Apr 25, 2012 6:39 AM   in reply to Robert Schmitz
    If executing that menu action did not work, it's not very likely a script
    would.
    What exactly happened when you pressed the button with that action?
    Apr 25, 2012 6:52 AM   in reply to Robert Schmitz
    Just add a Run a JavaScript action with this code:
    this.mailDoc();
    But like I said, I don't think it would work if the menu item didn't work,
    since they both do basically the same thing.
    Is Outlook set-up as the default email client on your system? Was the file
    saved before you tried to email it?
    Apr 25, 2012 7:16 AM   in reply to Robert Schmitz
    app.mailMsg(true) will create a blank message (only in Acrobat, not in
    Reader), but my guess is that wouldn't work for you either.
    It's probably a problem with the way Outlook is set up on the machine.
    May 10, 2012 7:43 PM   in reply to Robert Schmitz
    All you have to do is
    • make a button
    • attach the action "submit form"
    • when it asks for the email address just put "mailto:"
    • select PDF that you want returned.
    • then when you press that button it will open an email with the PDF attached
    • you can then fill in your email address
