Peter79879
How to center multiple text in a button
Apr 19, 2012 4:31 AM
Hello I have made a button in FW but it only centers the text correctly when I use one word.
When I type some thing like About Me it differs see attachment
    Apr 19, 2012 8:24 AM   in reply to Peter79879
    Are you using the Align panel? Select both the text and the rectangle simultaneously and choose the "horizontal center" and "vertical center" alignment options. (Or maybe just the "horizontal center" option in this case.)
    Be sure that the "To Canvas" option is off.
    Apr 22, 2012 10:29 AM   in reply to Peter79879
    Was this button a "rich symbol" from the Common Library? If so, are you editing the text from within the Symbol Properties panel?
    Unfortuntately, the version of Fireworks that I use (FW8) predates these features, so it's difficult for me to advise here. When I open the attached button, the text appears distored on the canvas. And in the symbol editor, the second word is missing entirely.
    Re-reading your last reply, are you saying that the problem occurs when you create the button or only when you scale the button? According to the following link, 9-slice scaling cannot be applied to a symbol containing text:
    http://help.adobe.com/en_US/fireworks/cs/using/WS4c25cfbb1410b0021e63e 3d1152b00d277-7ff4.html
    Apr 23, 2012 8:21 AM   in reply to Peter79879
    Sorry, I don't have these features...
    Just to be clear: In the example you've provided, there may be no need for 9-slice scaling as there are no rounded corners or other details that might distort when using a standard Transform command. (But perhaps you've provided a simplified example here?)
    Also, here's one workaround: If the button has a flat background, you could get away with inserting an "invisible character" to approximate the space. For example, insert a period (.) instead of a space and assign it the same color as the background.
    (Alternatively, I wonder if inserting a hard space, or non-breaking space, might work. I can't recall the keystroke for this—it might vary by operating system—but you could Google it and give it a try.)
    In case it's helpful to you, this 4-minute video offers a decent demonstration of the 9-slice scaling tool:
    http://colorburned.com/2010/03/use-9-slice-scaling-in-adobe-fireworks- cs4-to-scale-objects-without-distortion.html
    Apr 25, 2012 8:33 AM   in reply to Peter79879
    Whoah! All the content on that site (colorburned.com) seems to have disappeared overnight.
    Here's a link to the same 4-minute video from another site: http://happys365days.blogspot.com/2010/03/colorburned-use-9-slice-scal ing-in.html
