Philingtons
Out of memory error message
Apr 25, 2012 7:28 AM
Tags: #out-of-memory #error-message
I an using InDesign V7.5. It's been working OK for a couple of months. Suddenly I start getting an "Out of Memory" message that keeps popping up. Checking my activity monitor it shows InDesign using around 750Mb of ram with still a Gig of ram unused.
Can anyone shad any light on what is going on. Have tried zapping the PRAM.
Phil
  • John Hawkinson
    Jun 25, 2009
    Apr 25, 2012 7:45 AM   in reply to Philingtons
    Hold down Cmd and select About InDesign. What is the 3-dotted full version number?
    What OS release are you using?
    "Out of Memory" generally indicates a failure of InDesign to properly manage the memory it has allocated to it, rather than the machine or the operating system actually running out of memory. It's an internal bookeeping issue...
    More information about what you have open and what kind of documents you are working on might help. Do you have Live Preflight enabled?
  • John Hawkinson
    Jun 25, 2009
    Apr 25, 2012 7:55 AM   in reply to Philingtons
    Please update to 7.5.2.318.
    Download and install the 7.5.2 patch.
    Bob
  • John Hawkinson
    Jun 25, 2009
    Apr 25, 2012 8:01 AM   in reply to Philingtons
    Jul 16, 2012 11:42 AM   in reply to John Hawkinson
    Using InDesign version 7.5.333, Mac OS 10.6.8, getting "out of memory" message when using preflight in adocument which has lots of large photos.
    Jul 16, 2012 12:07 PM   in reply to Tryingtodothis
    Divide and conquer...
    Make a copy of the file. Delete half the pages. If the problem persists, delete half or what's left and try again. If the problem goes away, put back the deleted half and delete the half you originally left. Repeat until you isolate one page, then use the same technique to isolate the offending object.
