Adressing an object by it's id
Apr 25, 2012 7:37 AM
I'm failing to write a line that will adress a textframe by id (which is 3771) and then move it.
This is how my attempt looks:
app.activeDocument.textFrames.item.id(3771).move([0, 0, 7, 2]);
Any help is appreciated
  • John Hawkinson
    Jun 25, 2009
    Apr 25, 2012 7:46 AM   in reply to PrntScr
    It this JavaScript?
    You should use app.activeDocument.textFrames.itemByID(3771).
    Where did you find this .item.id() syntax?
  • John Hawkinson
    Jun 25, 2009
    Apr 25, 2012 7:58 AM   in reply to PrntScr
    Your answer to "where?" is "somewhere" but not-gonna-say? I see.
    Are you sure your ID is correct? What if you use
    var textblock = app.activeDocument.textFrames[0];
    ? Are your units set reasonably so that you would see a [0,4] move?
    Do you get an error?
  • John Hawkinson
    Jun 25, 2009
    Apr 26, 2012 10:01 AM   in reply to PrntScr
    Note that you can in fact use inline images here...
    Anyhow, I guess you've figured it out, but
    var myID = myTextFrame.id;
    merely sets myID to the ID number of the text frame. It doesn't mean that you can add parens after id() and parametrize an index through it.
    Glad you got it working!
