Today's Date within Date Range
Apr 25, 2012 8:48 AM
I have a BeginDate and EndDate in a database.  I want to be able to list those records if todays date is within the date range of BeginDate and EndDate.  I am unsure of the coding on this.  Has anyone done this and can give me some help? Thanks.
    Apr 25, 2012 8:50 AM   in reply to TheScarecrow
    Depends on the database platform as to exactly what function you'd use, but essentially:
    SELECT cols
    FROM table
    WHERE now() > BeginDate
    AND now < EndDate
    That's all there is to it.
    Some databases let you do BETWEEN clauses, so even neater
    WHERE now() BETWEEN StartDate and EndDate.
    Just be careful to do some testing as to what happens when today *is* the end or start date, you may want them included or excluded depending on your requirements.
    Apr 25, 2012 9:08 AM   in reply to TheScarecrow
    Right, so you need to find out what the correct function name is for your database platform.
    Apr 25, 2012 9:17 AM   in reply to TheScarecrow
    You're not using the CF function, as to do so would mean wrapping up the CF now() call in a CFQueryParam and passing it around as a variable, which is inefficient. I've never used FileMaker but Googled "Filemaker get current date" and it says to use "Get(CurrentDate)" - give that a go.
    Apr 25, 2012 9:59 AM   in reply to TheScarecrow
    No, you shouldn't have to convert anything.
    Assuming "Get(CurrentDate)" is correct (which as I said was from a quick Google, I've never used the DB you're using) it will return a date object. Assuming your dates are stored in the database as dates as well and not strings or something silly, it should be fine.
    What does the error say?
    Apr 25, 2012 10:07 AM   in reply to TheScarecrow
    Okay, well you need to help me out and find out what the function name is you need, as there's little point me doing that for you. You'll need to check the documentation for the database platform.
    Apr 25, 2012 11:34 PM   in reply to TheScarecrow
    Okay that's not quite what I meant but hey, if it works it works!
    Glad you got it sorted.
