I am in Acrobat X Pro. I used the "place muliple fields" down and across. How do I stop the data from repeating in the fillable boxes when I do? Working on a tight deadline. Thank you.
The values of fields with the same name will be identical, but when you use
this function the duplicated fields usually don't have the same name as the
original. Does your original field have a dot in its name? If so, that
might explain why this is happening.
So I have to name each bx individually? Don't beleiv ehtere is a dot in it's name.
Maybe you should double-check...
NO dots. I renamed and it worked, but there has to be an easier way to make mulitple fields without having to rename them each indivually.
Like I said, it usually works that way... Which version of Acrobat do you
have?
I think I follow what happenned. I will try tomorrow and see how it goes. Thank you.
Maybe you can share what you think happened, in case other users encounter
the same problem...
