I have been using PSE8 because of the full-featured version of ACR (v. 5.7 hosted by Adobe Bridge; not the version hosted by PSE8) for several years. To my dismay, this version of ACR does not support RAW files from Canon's 60D camera. Since I have been experiencing trouble using Adobe's DNG Converter, I am considering upgrading to PSE10.
Question: Does PSE10 contain the full-featured version of ACR or just the abbreviated version?
Thank you kindly.
Photoshop Elements 8 should not have been any different, even if you were using it through Bridge. The Bridge that came with Photoshop Elements on Mac before we released 9 with the Organizer, was always a feature reduced version. You should have seen the same in ACR. However, we have seen "glitches" in the past that somehow circumvented the intended behavior (maybe you had a CS4 product installed at some point?). So, in this case there is no way to "fix" the behavior, as it is working as intended. It was actually your PSE8 that wasn't working right.
Brett,
My copy of PSE8 has 2 versions of ACR: the abridged version hosted by PSE & the version hosted by Bridge. The Bridge version includes the tone curve, detail, HSL/grayscale, split toning, lens correction panels, etc. As I recall, Barabara Brundage even mentioned this in her Missing Manual book "Photoshop Elements 8 for Mac".
No, I have never owned a CS4 product.
Brett,
I have no reason to doubt you. However, I don't know how I could have installed PSE8 incorrectly years ago. It wasn't until a few weeks after installation that I was reading Brundage's book where she has a sidebar titled "Hidden Feature Alert: Editing Raw Files in Bridge". This is the CS4 version. To access it, I Control-click on a thumbnail in Bridge & choose "Open in Camera Raw". Bingo.
Editing Raw files in Bridge isn't really a hidden feature. But it should still have opened the files in the same limited version of Camera Raw that Elements uses and not behaved any differently. As I mentioned before, the copy of Bridge that comes with Elements is also limited when compared to the Bridge that comes with the pro products. It sounds like this book was written under a misunderstanding, the author encountered the same glitch and thought this was some secret that could be exploited. Reports of this glitch were quite common.
I think it's probably one of those things that was overlooked, whether by mistake or on purpose, i cannot say, but 100's if not thousands of people have the same "glitch" using pse 8 on macs.
Examples of some other "overlooked" functions in various versions of elements
Photoshop elements 1 has an easy workaround for getting a layer mask
Photoshop elements 2 has a full brushes palette just like photoshop 7
Photoshop elements 3 has the Select>Color Range command
Photoshop elements 4 has Smart objects
Photoshop elements 5 has Lab mode
Photoshop elements 6 has an editable black and white adjustment layer
These are just a few of many functions in elements that aren't "supposed" to be there.
I should add that most of the above require an action from photoshop to enable them, but they are there.
