I burned my movie to DVD and when I put the disc in it automatically loads the disc and opens the Sub menu/chapter menu once I close that and double click on the DVD it starts the first play and then loads the Main Menu just as it should; so why would it automatically open the Sub menu when incerted into the DVD drive?
I think this is an auto run .ini problem but not sure if I can fix it with Encore or if I have to edit the disc image myself; have not been able to test it on a DVD machine only computer this happens on two different computers and windows versions.
Any help would be appreciated thank you.
I just tested 4 other discs I burned of the same exact project and my system is opening them up with VLC to the Sub menu when I double click the DVD it opens in WMP but I can no longer get the default action (Main Menu In) to work on any program
Not sure exactly what you mean by the Sub menu being linked twice or how to find out or fix it; there is no reason I would have to do anything out of the ordinary it should be a simple setup.
Thank you for all the help so far.
I am not 100% sure, but I think http://www.imgburn.com/index.php?act=download allows more than one drive... you would create an ISO or folder in Encore, then use Imgburn for the actual writing process
