Hi team,
Is there a way to utilise 3D objects in Flash for users to manipulate? I can see how I can export an image sequence and fake it but is there any way that Flash can acutally use the 3D object?
i would really like to make a 3D interactive object for a Google sites website, is there any way that you can point me towards to do this?
Just a basic revolve/rotate would be a good start.
Cheers
sub
Yes. Very easy actually, except for texturing. Stage3D lets you do realtime 3D on mobile devices, the web, desktop, etc.
I use a framework called Flare3D mostly. It comes with a 3dsmax 3d plugin. It installs custom materials in 3dsmax (2010 and above) and you need to texture your object using them (I find) as the built in standard material converter doesn't work too well. It also adds a menu item to 3dsmax that lets you export your object in a format called f3d.
Grab the YellowPlanet tutorial (Flash Builder) to see how easy it is to use. After you set up a basic scene, the default nature is just to show the 3d object and allow you to rotate/zoom around the object without you coding it at all.
