Fade out
Apr 25, 2012 11:08 AM
Tags: #fade #out
I have a SWF that does not fade in or out.  When I put it into Captivate it Fades in and out, even though I selected it to NOT Fade in or out.  Help?
    Apr 25, 2012 1:13 PM   in reply to ChadXSO
    Just this question: is this SWF perhaps on the last slide of the project? Because by default the End of the project fades out (Preferences, Project, Start and End)
    Lilybiri
    Apr 25, 2012 1:19 PM   in reply to ChadXSO
    OK, so open Preferences (Edit menu or SHIFT-F8), and uncheck Fade in of first slide and Fade out on last slide in Project, Start and End
    Lilybiri
    Apr 25, 2012 7:05 PM   in reply to ChadXSO
    If you do NOT have Project > Start and End options set to Fade in or Fade out, have you checked whether or not the inserted SWF is set with a Transition to Fade in or Fade out?
    Apr 25, 2012 8:20 PM   in reply to ChadXSO
    I don't think you understand me.  Select the SWF object that you inserted into the Captivate slide and look on the Properties tab in the Transition accordion to see whether it has a Fade In or Fade Out transition applied.
    Fading effects can be on the overall project, or on SWF objects at the Captivate level, or applied in Flash when the object was originally created there.
    You claim the project has no fade in or fade out and that when you created the SWF in flash it did not have a fade in or fade out, but I'm not yet certain that you have ruled out whether the SWF in Captivate has a transition applied.  This would likely be the default setting for all animations inserted into a Captivate project.
    Apr 26, 2012 2:26 AM   in reply to RodWard
    Rod,
    Right at the start of this thread, user claimed that he turned off Fade in/Fade out for the SWF, that is the reason I asked about the Start/End fade in/out.
    Lilybiri
