Fail to pass datetime value to store procedure
Apr 25, 2012 6:27 PM
I have a store procedure which will receive the date passmeter and I write it as following:
<cfif IsDefined("form.yy")>
     <cfprocparam cfsqltype="CF_SQL_TIMESTAMP" value="#CreateDate(form.yy, form.mm, form.dd)#">
<cfelse>
     <cfprocparam cfsqltype="CF_SQL_TIMESTAMP" value="null" null="yes">
</cfif>
When I did not input the day, it runs correctly.
However, it returns me the error when I input the day:
Conversion failed when converting datetime from character string.
How can I solve the problem?
    Apr 26, 2012 2:59 AM   in reply to Phinehas1234
    Your cf code looks ok.  What does the stored proc look like?
    Apr 26, 2012 3:19 AM   in reply to Phinehas1234
    Shouldn't the year be 4 digits instead of 2, that is, yyyy? In any case, you should validate the input values. (Update: The following example is a simple validation routine. You could make yours as sophisticated as you want.)
    <!--- Validate form field values yy, mm and dd before passing them to stored procedure --->
    <cfif IsDefined("form.yy") and isNumeric(form.yy & form.mm & form.dd) and isDate(form.mm & "/" & form.dd & "/" & form.yy)>
    <cfelse>
        <cfprocparam cfsqltype="CF_SQL_TIMESTAMP" null="yes">
    </cfif>
    Apr 27, 2012 12:45 AM   in reply to Phinehas1234
    Fine. Please kindly mark the question as answered.
