Pr CS7 Feature Requests
Apr 25, 2012 8:07 AM
I am excited about getting my hands on CS6, and congratulate the Adobe team for their hard work.
However...
I haven't seen anything in the web pages or videos about these features that are vital to working editors, already requested by me and many others, but still not implemented or announced here:
http://blogs.adobe.com/premiereprotraining/2012/04/premiere-pro-cs6-wh ats-new-and-changed.html
Please join me in requesting these features be implemented ASAP:
Ability to save track or clip based audio effect user presets.
A Scrub Audio shortcut toggle - NOT a user pref.
Ability to map multiple Keyboard Shortcuts to the same function (a la Avid: E & R keys, same as I and O).  Very convenient for two-handed editors.
Show Match Frame (Add Edit) function.
Heal Match Frame (Add Edit) command.
Dupe Detection indications in Timeline.
Shortcuts to Scale image zoom in Source and Program tabs.
Temporary Snap on or off (AKA Reverse Snap Behavior) keyboard modifier.
More obvious indicator that Timeline Snap is on.
Indicator on Clips in the Timeline that indicate Frame Blend is enabled.
Ripple Sequence and Chapter Markers.
Ripple Audio Track Keyframes.
Ability to save user/custom transition presets.
Constrain clip time movement between tracks by holding shift key, just like all other applications.
Lasso multiple keyframes.
Constrain keyframe values while holding shift key and moving them in time.
Clip Label only works on AV clips.  Not V-only.  Please make it work on V-only clips as well as AV clips.
A Track Matte function that allows us to pan and scale the clip being matted without affecting the matte size or position.  CRITICAL!
Ability to change the dimensions of a Sequence after it's been created.  (Actually, this may be in CS6; I'm not clear.)
Make it possible to solo and mute audio in the Timeline panel; not just the Audio Mixer.
Make it brilliantly obvious when audio tracks are being soloed (or muted); not some tiny little icon that's 1/100 the size of the interface. When you mute or solo a track in the Audio Mixer, that should be indicated in the Timeline icons and tracks as well, perhaps by shading or color, stripes, etc.
Please give us the ability to copy between in/out in a Sequence and paste elsewhere.  Workaround is to add edits (razor) where you want the in and outs before you can copy that region.  Or, you can set in/outs and lift or extract, then immediately undo.  This is a time waster; counterproductive.
No Auto-Saving right in the middle of an operation or playback, please.  Make it wait for a few seconds of inactivity before it kicks in.  No auto-saves when no changes have been made; long periods of inactivity.
Please make all Adobe apps NOT force the computer system to switch to the app that's launching or saving after that operation is compete.  It's VERY ANNOYING to be typing an email and have Adobe switch apps for me when it decides it's ready.  VERY ANNOYING.
Please after using Clip > Scale to Sequence, DO NOT have the new Scale factor in the Motion tab change the clip's scale to 100%.  That's misleading, confusing and I see no good reason for that number to change.  If I'm using a HD clip in an SD Sequence, I want to know exactly how much more I can scale it up before it exceeds the actual scale of 100%.  So, rather than it showing me 100%, it should show 40%, or whatever the real scale factor is.
Provide a way to save TRACK AUDIO FX settings.  I work in a native Sequence to edit, and copy and paste it into an AJA sequence for color correction.  ALL my TRACK BASED AUDIO needs to carry over into the new sequence.  Without a way to save my settings, I have to manually recreate them by jumping back and forth between the old and new sequence.  Time-killer.
Change the paste behavior into a new Sequence to exactly match the track configuration from the "parent" (copy from) sequence.
Have the Program monitor remember the Zoom level for each Sequence; don't have Zoom scale set universally by the project.  When switching between Sequences of different size, we have to reset the Zoom level each time (and with the mouse, too; not a keyboard shortcut).  Time waster.
Consistent Mouse Wheel behavior across all apps in CS, please.  Ae, Au, and Pr have different scroll wheel behaviors.
I intend to submit these to Adobe AGAIN a nanosecond after I discover they're not in Pr CS6.  I hope you will all do the same.  And share your suggestions with us.  Strength in numbers.
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Replies 1 2 Previous Next
    Apr 25, 2012 8:27 AM   in reply to Jim Curtis
    You have some nice suggestions, but I'd like to comment on a few.
    This may well be possible using the new Adjustment Layer if you apply the matte to that instead of the video clip itself.
    This is at least possible by dropping a clip into the sequence that doesn't match.  PP will ask if you want to change the sequence specs to match the clip.  (Not sure if you can do this manually, but honestly, given the ability to have multiple sequences in any given project, it seems to me a rather low priority request).
    This is now possible in CS6.  The Audio meters next to the timeline have Solo buttons.  No need to switch to the Mixer pane.
    With Adobe Transmit, that will no longer be the case.  You'll work in native Adobe sequences, and that will be sent to your hardware output for monitoring.  You'll also now get all the benefits of Mercury Hardware Acceleration out to your monitor.
    This happens now, assuming you have the proper tracks targeted in the Paste sequence.  (It would not be good for PP to simply ignore track targeting, if that's what you're asking.)
    This happens now (at least it does for me using 5.0 on Windows 7).
  • joe bloe premiere
    Dec 6, 2009
    Apr 25, 2012 8:40 AM   in reply to Jim Simon
    HOORAY!!!
    Apr 25, 2012 11:02 AM   in reply to Jim Curtis
    I could use Fit to Frame, but the aliasing is unsatisfactory.
    I thought you meant timeline zoom level.
    You may want to look into your graphcics driver (or get a new card).  My Fit looks just fine.
    Apr 25, 2012 11:04 AM   in reply to Jim Curtis
    I'm talking about pasting into a newly created sequence.
    So was I.  In fact, that's exactly how I tested it.
    Apr 26, 2012 8:22 AM   in reply to Jim Curtis
    That last can be achieved using the new adjustment layers.
    Apr 26, 2012 9:50 AM   in reply to Jim Curtis
    Dont forget to post them to insure they get to Adobe.
    Apr 26, 2012 10:38 AM   in reply to Jim Curtis
    I generally have a different non-CUDA effect or effects on each clip in the timeline.
    So you cut the Adjustment Layer to match the clips.  Apply your effects to that, and then just turn the layer off.  If each part of the AL is grouped with the actual clip, they'll trim in sync.
    Apr 26, 2012 10:37 AM   in reply to Jim Curtis
    make trims and tweaks in real-time
    Your other option here is to apply effects after all trimming and tweaking.
    Apr 26, 2012 10:50 AM   in reply to Jim Curtis
    There should be a CS6.5 revision before CS7 and I expect it to be full of new features, bug fixes and offer better integration between SpeedGrade and the rest of the suite.
    Apr 26, 2012 12:41 PM   in reply to Jim Curtis
    No harm in making things easier, I agree.
    But for now...
    May 9, 2012 11:02 AM   in reply to Jim Curtis
    Keyboard shortcuts:  there's a hidden feature.  Hold down Ctrl-Shift-Alt while accessing the keyboard shortcuts menu, and it'll add a 'Clipboard' button that'll allow you to dump out all the keyboard shortcuts & paste them to a text file.
    Snap behaviour toggle:  Depends on what's snapping:  if you're talking about clips snapping to edges/CTI while dragging around, the 'S' key toggles snap on/off.  For the playhead itself, holding shift while dragging will turn on snapping temporarily.
    'Toggle audio while scrubbing' is now an assignable shortcut.
    Mouse behaviour:  you can choose to have the mouse wheel scroll horizontally or vertically in the prefs.  (Don't get why people would want to scroll left/right in the TL with the mouse wheel, that seems weird to me, but whatever.)  And I think that they fixed the inversion issue for the alt-wheel zooming behaviour.
    Keep 'em coming, good requests!
    Cheers
    May 9, 2012 11:04 AM   in reply to Wil Renczes
    Because I rarely have more than three layers, but often have a sequence that's longer than 4 minutes, and wheel scrolling is easier than grabbing the scroll bar.
    May 9, 2012 2:19 PM   in reply to Jim Curtis
    That is possible already.  (Win7)
    May 9, 2012 3:22 PM   in reply to Jim Simon
    Ah.  I tend to use the zoom keyboard shortcuts: either zoom out a couple of times, reposition the CTI, zoom back in, or even handier if you need to to broader jumps, hit the '\' key to zoom out to full, seek to the new position, hit '\' again to zoom back into your previous zoom level...
    May 9, 2012 3:29 PM   in reply to Jim Curtis
    Nice!  Thanks, Wil.
    Are there any other hidden features?  Why the secret?
    Not that I can recall, we don't usually have easter eggs per se.  There's some debug helper stuff that lets us turn on diagnostics type stuff for playback latency, etc.  Mostly useless to people outside us engineering geeks.
    I think the only reason the keyboard shortcut dump was left 'hidden' is because it was tossed in as a helper utility by an engineer - it wasn't a designed feature, so it didn't go through the usual design process for a user facing feature.
    Sep 8, 2012 9:00 AM   in reply to Jim Curtis
    Jim Curtis wrote:
    I should have been more specific.  I can lasso mulitiple effect keyframes in the effect panel, but not in the Timeline.
    Use the Pentool in the timeline
    Sep 8, 2012 9:11 AM   in reply to Jim Curtis
    Jim,
    I have not read the entire thread, so this might have been addressed above, but:
    Does toggling the Snap ON/OFF, via the S key, not work in this case? Perhaps I am missing something.
    Off to read more.
    Good luck,
    Hunt
    Sep 8, 2012 9:17 AM   in reply to Jim Curtis
    And, just announced a few days ago, network support is coming...
    Adobe Anywhere http://forums.adobe.com/message/4682127
    -Announced September 2012 for "future versions" of Premiere Pro
    -NO information on pricing or availability date
    Sep 8, 2012 9:18 AM   in reply to John T Smith
    That is great!
    Hunt
    Sep 8, 2012 9:21 AM   in reply to Jim Curtis
    Jim,
    Got you. Thanks for the clarification.
    Also, my apologies for getting to this thread so very late. Guess that I was out of the country, when it started, and until Ann's tip on the Pen Tool, had just not seen it.
    As for an indicator, whether Snap is ON/OFF, I agree. Something that the human eye can see would be nice...
    Good luck with the requests.
    Hunt
    Sep 8, 2012 9:24 AM   in reply to Jim Curtis
    Jim,
    I also agree that Keyframes' states with color indicators, would be nice.
    Have not worked with the new AE, but going back a bit, the difference between the normal state of the Keyframe buttons, and their rollover state was about 1% darker gray. For days, I struggled, thinking that my Keyframe buttons were "grayed out." I felt that they looked better, and were easier to see and use, in the PrPro interface, than the one in AE. [Took a post to AE Forum, and someone just telling me, "click on it, and you will see it Add Keyframe (or whatever I was trying to do)." It worked - they looked grayed out... ]
    Thanks for taking the time to think these requests through, and for the Feature Requests.
    Good luck,
    Hunt
    Sep 8, 2012 1:33 PM   in reply to Jim Curtis
    All good points.
    Can't say how many times I've wished for that.
    That would be handy.
    No idea why it is not there, this seems like a no brainer. At the very least a context menu to achieve that quickly a la PS' Show/Hide Layers would be nice. This also goes for expand/collapse tracks and so on.
    Indeed. The Auto-Save function is very much useless as means of backwards recovery. Often all you get is 5 projects which are just like your current project so if something goes wrong (as it often does with this crash magnet of a  software) - good luck. Retarded and yes, very annoying when it kicks in.
    Adobe seems infatuated with tiny controls and off the cuff UI behavior. This has been going on for ages and I want to strangle the person(s) who are responsible for that. One needs to fevereshly hunt for the right pixel to click on to get the context menu or action desired; Mouse clicks or wheel works in some windows w/o focus and doesn't in others; They seem to have missed the obvious that when you press ALT in Windows it switches over to the app menu (nothing new either, been like that forever) so expanding/contracting the timeline with Alt+Wheel always results in lost focus and required extra clicks/operations at best, doing something undesireable at worst; Dragging effect into timeline clip leaves focus in Effects panel. WTF!?; Can't begin to count how many times I've mangled my project because when selecting items the UI for some reason goes into renaming mode for example.
    In PS I can focus into a value and adjust it with the mouse wheel: good. In Premiere you need to drag an imaginary slider or just outright type the value in. Good luck adjusting effect or any other values by a tick (or two even) with the mouse.
    I would also welcome ability to re-shuffle audio tracks on timeline either with drag or move up/down
    Another thing is (Context) Menu management. Why can we do it in PS but not Premiere, mind boggling. Why do I always have to see 20 million items many of which I have no need for. All that is good for is constantly searching for the right item on the menu. Although I use PS CS4 so that may have changed there too now.
    Is it really so hard to provide content based custom actions? I don't have Audition, how about being able to create a custom menu item whereby I can edit my asset item using MY program?
    Why is the option to for example Edit in Photoshop, displayed (albeit grayed out) when that item cannot possibly be edited in PS and Premiere knows it? And that goes for other items as well. I'd love to see things and only things relevant to my work environment and its state. I don't need to see full lists of everything every time. I don't care for exporting to Apple formats, why can't I hide those presets so my drop-down menu is manageable? I don't care if it takes me 2 weeks to set the UI up according to my needs, but it should be possible.
    And one more. "Clear" means just empty everything in a container. It is highly unintuitive to call action "Clear" when in effect it removes selected item(s). Here's a tip: "Remove" has been used for that by everyone else and for good reason, too.
    Sep 8, 2012 8:54 PM   in reply to Arsinn12
    It works properly for me, at least back to CS5.
    Sep 28, 2012 7:26 PM   in reply to Jim Curtis
    You have wrote alot there in your post, I hope the developers GET IT, since they are not dealing with clients like we are they don't understand we wnat to be able to do it easy and fast and not alot of motions we have to go through to get the job done. they think they are doing there job putting options in wierd places and we all sut back and say why did they put that there. Just think we could make them look really good if they would listen more.
    They should never take features away from a program they leave what they have and add to it . Example i know some of you out there run Premier Pro 2.0 you can burn and do some limited authoring from the timeline. Now why didn't they just leave all of that simplicty and when you clink D.V.D. layout encore opens up and wow your up and running i still use 2.0 for that reason not alot of fuss. now i know some of out ther will correct me on this please do . I recently downloaded the trial version of 6.0 but i couldn't try the encore feature because it wasn't included in the trial
    Sep 28, 2012 9:36 PM   in reply to Marc 3950
    I believe that with the advent of the Creative Cloud, Adobe should be working on integrating the UI on all of the programs so that it feels like one big application.
    Why shouldn't I be able to open the new "Adobe Video Program", gather my clips and other resources, and place them on a timeline, just like Premiere Pro, but then I should be able to toggle the track the way I do in After Effects and apply all of the effects that I would have in After Effects. When I right click on the audio, I should be able to chose "Edit Audio" and get all of the features of Audition right in the same UI. When I click back over to the timeline, all of the video and audio effects have been applied to the material on my timeline.
    Why are these all treated as separate applications? I don't really think of them as separate. I think of them as "Adobe". We edit video, add effects, use 3D space,  fix our audio, all of that. We are creating a video. It doesn't matter if it is a movie destined for the big screen or a Webisode, or a TV commercial. We take video and audio and do interesting things to it to get a final result. Why not be able to do it all in one UI with tabs across the top labeled Video, Audio, Titles, Effects - etc? And when we export, why shouldn't we just ask to create the DVD by clicking on the DVD tab.
    Sure, it would require sophisticated memory handling, but that is what the Adobe engineers get paid the big bucks for.
    The Creative Cloud should be one application with multiple tabs. That's my two cents, and is probably worth what you paid for it, but there it is.
    Dec 26, 2012 10:14 PM   in reply to Jim Curtis
    Greetings!  I'd like to chime in with 2 suggestions I've just sent to Adobe.  Hopefully Adobe addressed these 2 issues since they probably affect every editor who uses Premiere on a daily basis:
    Here they are:
    Font Folders
    Ability to create folders and subfolders at the top of the font list, and drag & drop fonts into these folders to organize them.  Three potential types of 'master' folders could exist, 'Program Fonts', 'CS Fonts' and 'Projects'.  'Program Fonts' would be font folders and sub-folders that only exist within the current CS program. In this way, a Premiere Pro user could create a "Wedding Videos" font folder that only has fonts that are appropriate to that type of video. Folders under 'CS Fonts' would appear across all CS programs, so a collection of fonts in a 'Favorites' folder created in Photoshop, would also be available/modifiable in Premiere and AE, etc. The 'Projects' folder would automatically create a new folder for each project created in the respective program and keep track of all fonts used in that project.  So should an editor need to reuse the same fonts that were used in another project, the editor could simply reference the font folder with that project name. For maximum usability, the same font should be able to occupy several folders, and font folders would need to have the same functionality as bins: renaming, twirling up/down, deleting, etc.
    Having zero built-in font organization, is akin to using Premiere/AE without bins, or Photoshop/Illustrator without layers.  In other words, it's a complete mess.  Why should editors have to scroll through a list of 200+ installed fonts that are completely inappropriate for a certain title, every time they want to locate and compare the 5-10 fonts that are appropriate?  Allowing this kind of built-in font organization, with a simple drag & drop interface (just like Premiere Pro allows users to create bins/sub-bins and drag-drop appropriate assets into them) would be a God-send and set Adobe apart as the first software company to address font management in this way.
    Anchor keyframes toggle in Effect Controls window
    Much more often than not, editors need keyframes to retain their position relative to a clip's in/out point when trimming, slipping or adding a transition to the clip. This could be done with an 'Anchor' toggle for each Effect in the Effect Controls window. By toggling on the 'Anchor' icon for an effect, all keyframes on the first half of the clip would automatically retain their position relative to that clip's in point when trimming, slipping, or extending the clip with a transition. In other words, keyframes positioned 1 and 30 frames from the clip's in point would remain exactly 1 and 30 frames from that clip's in point, regardless of future trims/slips/transitions applied. The same would be true for keyframes positioned on the second half of a clip: they would maintain their position relative to the clip's out point.
    Why is this feature important to you?
    Consider these common editing problems:
    1) An editor adds Motion and Video Effect keyframes to a clip, but later needs to slip the clip. The content slips, but so do the keyframes, often throwing them outside the visible range of the clip!
    2) An editor adds keyframes to a still's in/out points to create a Ken Burns effect, and then adds a Cross Dissolve between the still and the next still. Suddenly, the keyframes are no longer at the still's out point, and the motion effect abruptly stops halfway through the Cross Dissolve. To fix this, the editor needs to manually realign the keyframes with the clip's new out point at the end of the transition.  Now consider having to do this for 50+ stills after adding Cross Dissolves between them! An editing nightmare!
    Allowing keyframes to automatically 'anchor' relative to a clip's in or out point would instantly solve these and many more all too common editing headaches, and therefore be a true God-send in terms of editing efficiency!
    Comments? Ideas? Improvements on these ideas? Please share! ...and ask Adobe for these tools as well if you feel they would help you too!
    Dec 26, 2012 10:25 PM   in reply to PierreLouisBeranek
    Well, as far as fonts go, you have a style library in the Premiere Pro Titler. All you have to do is set up your favorite fonts at your favorite size using your favorite styles and you can just call up the one that you have named "Wedding" or "Business" or whatever.
1 2 Previous Next
