Accessing url encoded variables in flash as3
Apr 26, 2012 2:34 AM
I don't know if its the right way to call this problem but pls bear with me.
http://mydomain.com/trackUser.php?userId=001
I want to get the variables included in the url above to be used in my flash project.
I have a code in my flash that determines if the user is a male or female and output back the same url but with additional variables on it.
http://mydomain.com/trackUser.php?userId=001&score=9
Any reply is much appreciated.
    Apr 26, 2012 4:32 AM   in reply to xxxheeroxxx
    Here are a few approaches to getting the query string data...
    AS3 Get URL Variables
    http://mikethenderson.com/2009/02/as3-return-query-string-value-versio n-2/#more-105
    OR
    In your HTML:
    var flashvars = {};
    if (swfobject.getQueryParamValue("chosenCLIP")) {
      flashvars.clip = swfobject.getQueryParamValue("chosenCLIP");
    swfobject.embedSWF("myMovie.swf", "myContent", "550", "400", "9.0.0", "", flashvars);
    And the clip variable will be available as a FlashVar to your movie:
    var theClip = loaderInfo.parameters.clip;
    OR
    In the swf... Try:
    ExternalInterface.call("window.location.href.toString");
    and parse the string
    Apr 26, 2012 7:24 AM   in reply to xxxheeroxxx
    Apr 26, 2012 7:59 AM   in reply to xxxheeroxxx
    Search Google using terms like "AS3 PHP MySql tutorial"
    May 31, 2012 5:19 AM   in reply to xxxheeroxxx
    Im going to go with what Ned said about using
    so the above will pull somthing like this in as a string...
    http://www.aidanmack.co.uk/?var1=goo
    Then im going to use split to split the string on the =
    and that will give me the datas im after!...
    Just seems a bit crude?...
    No built in class or anything we can use in flash?
    meh it does what i want it to do anyway!
