StageVideo on iOS
Aug 29, 2011 2:17 AM
Hi all,
It would be so great if there would be stagevideo support for iOS devices. I know there's a workaround using StageWebView, but I need to be able to place objects on top of the video.
Does anyone know if, and if so, when Adobe plans to release support for StageVideo on iOS?
Karel
    Aug 29, 2011 2:45 AM   in reply to KarelBrascamp
    You can do call the native video player from the IOS using stagewebview and play H.264 videos.
    Aug 29, 2011 4:49 AM   in reply to KarelBrascamp
    I think its possible if you not occupy the whole stage width and height. and you can use the space for your purpose?
    Sep 3, 2011 3:30 AM   in reply to KarelBrascamp
    Hello,
    I'm trying to do the same thing with the new AIR 3 beta 2 in Adobe Labs. With the new stagevideo API available for iOS we should be able to play a h264 movie. I'm trying it on a iPad 1 with iOS 4.3.5 with no luck. I get the sound playing, but no video. I do get the "Accelerated" with GPU though....
    Have you tried it yourselft with better results?
    thanks..
    sebastian
    Sep 6, 2011 5:51 AM   in reply to sebelga
    Hello Sebelga,
    I'm trying the same thing than you with an iPad 1 with iOS 4.3.3 and I have the same result. I have the sound but no video with the gpu render mode.
    Adobe, do you know if it's a known issue with the iPad 1 ?
    Thank you
    Loïc
    Sep 6, 2011 8:27 AM   in reply to KarelBrascamp
    I created a bug at Adobe. You will find there a zip file with the test project I did.
    At the end I could see a portion of the video "outside" the stage.. Check it to understand.
    https://bugbase.adobe.com/index.cfm?event=bug&id=2960080
    seb
    Sep 19, 2011 12:31 AM   in reply to KarelBrascamp
    @karelBrascamp : Is it possible to get your example files ? i spent my week end trying to do it on android + ipad2... (i successfully traced the runtime as the latest airt3 beta, but still no stagevideo available)
    Sep 20, 2011 1:50 AM   in reply to Arthy the crab
    Ok i did successfully in integrating VideoStage and play accelerated video, but performance are very bad and far from expected, even if followed adobe recommandation from Adobe AIR TV article : http://www.adobe.com/devnet/devices/articles/video_content_tv.html.
    • Video codec: H.264, Main or High profile, progressive encoding
    • Resolution: 720i, 720p, 1080i, or 1080p
    • Frame rate: 24 or 30 frames per second
    • Audio codec: AAC-LC or AC3, 44.1 kHz, stereo
    • Combined bit rate: up to 2Mbps (or higher depending on available bandwidth)
    • Audio bit rate: up to 192 kbps
    • Pixel aspect ratio: 1 × 1
    performance on Xoom tablet are not good. Did someone managed in configuring AIR3 app + video encoding to fit expected results (0% CPU, and 100% GPU video decoding as i understood) ????
    Dec 7, 2011 6:50 AM   in reply to KarelBrascamp
    Hey guys, I've put together an iOS Stage Video class that works great on iPad/iPad2 (have yet to test it on my iPhones), this should help you out! It's not perfect, but it works like a charm!
    You will have to add in the following compiler arguments to your Flex project:
    -swf-version=13 -target-player=11.0
    and in your app descriptor file set the rendermode to 'direct'
    <renderMode>direct</renderMode>
    you must also set the 'backgroundAlpha' to 0 on your main component
    usage:
    var path:String = new File(new File( app:/path/to/mp4 ).nativePath).url;
    var vid:iOSStageVideo = new iOSStageVideo( path , 1024 , 768 );
    vid.addEventListener('videoDone' , function():void{
    vid.stopVideo();
    container.removeChild( vid );
    removeElement( container );
    container = new UIComponent();
    container.width = stage.stageWidth;
    container.height = stage.stageHeight;
    addElement( container );
    container.addChild( vid );
    and here is the class:
    package
              import flash.display.Sprite;
              import flash.display.StageAlign;
              import flash.display.StageQuality;
              import flash.display.StageScaleMode;
              import flash.events.Event;
              import flash.events.NetStatusEvent;
              import flash.events.StageVideoAvailabilityEvent;
              import flash.events.StageVideoEvent;
              import flash.geom.Rectangle;
              import flash.media.StageVideo;
              import flash.media.StageVideoAvailability;
              import flash.media.Video;
              import flash.net.NetConnection;
              import flash.net.NetStream;
              [Bindable]
              public class iOSStageVideo extends Sprite
                        private var videoPath:String;
                        private var videoWidth:Number;
                        private var videoHeight:Number;
                        private var _sv:StageVideo;
                        private var _vd:Video;
                        private var _obj:Object;
                        private var _ns:NetStream;
                        public function iOSStageVideo( path:String , w:Number , h:Number ){
                                  videoPath = path;
                                  videoWidth = w;
                                  videoHeight = h;
                                  addEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
                        //stage is ready
                        private function onAddedToStage(e:Event):void{
                                  stage.scaleMode = StageScaleMode.NO_SCALE;
                                  stage.align = StageAlign.TOP_LEFT;
                                  var nc:NetConnection = new NetConnection();
                                  nc.connect(null);
                                  _ns =  new NetStream(nc);
                                  _obj = new Object();
                                  _ns.client = _obj; _ns.bufferTime = 2;
                                  _ns.client = _obj;
                                  _obj.onMetaData = MetaData;
                                  _sv = stage.stageVideos[0];
                                  _sv.viewPort = new Rectangle(0, 0, videoWidth , videoHeight );
                                  _sv.attachNetStream(_ns);
                                  playVideo();
                        //video is ready, play it
                        //public, can be called externally
                        public function playVideo():void{
                                  _ns.play( videoPath );
                                  _ns.addEventListener(NetStatusEvent.NET_STATUS, videoStatus);
                        //required metadata for stagevideo, even if not used
                        private function MetaData(info:Object):void{ }
                        //get video status
                        private function videoStatus(e:NetStatusEvent):void{
                                  switch(e.info.code){
                                            case "NetStream.Play.StreamNotFound":
                                                      //do something
                                                      break;
                                            case "NetStream.Play.Start":
                                                      //do something
                                                      break
                                            case "NetStream.Play.Stop":
                                                      stopVideo();
                                                      break;
                                            case "NetStream.Buffer.Empty":
                                                      //do something
                                                      break;
                                            case "NetStream.Buffer.Full":
                                                      //do something
                                                      break;
                                            case "NetStream.Buffer.Flush":
                                                      //do something
                                                      break;
                        //stop and clear the video
                        public function stopVideo():void{
                                  _ns.close();
                                  _ns.dispose();
                                  dispatchEvent( new Event('videoDone', true ) );
    Feb 11, 2012 6:55 AM   in reply to KarelBrascamp
    Can someone please provide a Flash Professional CS5.5 solution for StageVideo on iOS.  A FLA file would be preferred.  I have used StageWebView successfully on an iPad.  I have tried using various document classes but cannot get the video file to play.  The solution must stream the video file from a remote server (NOT A FLASH MEDIA SERVER).  Are there any settings that need to be adjusted within Flash Professional CS5.5?  Remember, I DO NOT want a Flash Builder solution only Flash Professional CS5.5!
    Mar 13, 2012 11:40 AM   in reply to KarelBrascamp
    Did anyone ever come up with a StageVideo example for Flash CS 5.5?
    Dave
    Mar 25, 2012 12:38 PM   in reply to KarelBrascamp
    Below is the Flash CS5.5 solution. Make sure your using AIR 3.1 and the AIR for iOS rendering setting is set to GPU.
    package {
              import flash.desktop.NativeApplication;
              import flash.desktop.SystemIdleMode;
              import flash.display.MovieClip;
              public class Main extends MovieClip {
                        private var VIDEO_URL:String = "http://www.website.com/video.mp4";
                        private var netConnection:NetConnection;
                        private var netStream:NetStream;
                        private var video:StageVideo;
                        public function Main() {
                                  NativeApplication.nativeApplication.systemIdleMode = SystemIdleMode.KEEP_AWAKE;
                                  netConnection = new NetConnection();
                                  netConnection.connect(null);
                                  netStream = new NetStream(netConnection);
                                  netStream.client = this;
                                  video = stage.stageVideos[0];
                                  video.attachNetStream(netStream);
                                  video.viewPort = new Rectangle(0, 0, 480, 270);
                                  netStream.play(VIDEO_URL);
                        public function onMetaData(dataObj:Object):void {
                                  // Do nothing.
    Apr 25, 2012 12:55 PM   in reply to billo
    for me it only plays sound, no video visible
    Apr 26, 2012 4:50 AM   in reply to franky303at
    franky303at -- What version of Air are you using?  I used Air 3.1 for this file.  Did you set rendering to GPU?  Did you test it on the device?
    Apr 26, 2012 8:08 AM   in reply to billo
    Tried setting both renderMode "direct" and "gpu". - Using AIR 3.2 SDK ...   And yes, only testing on ipad 2 with iOS 5.1.  Both target ipa-debug and ipa-ad-hoc ...   Video is mp4 with h264 codec.
    May 18, 2012 5:52 AM   in reply to KarelBrascamp
    The tutorial posted here: http://01am.co.uk/comment/2 is working perfectly for me.
    However, I get no audio. The mp4 file itself contains audio (when played in Quicktime) but is silent when played in my IOS app.
    Is there something I need to do to activate StageVideo's sound? Has anyone else had similar issues?
    Jul 21, 2012 5:31 PM   in reply to DanaBrousseau
    I had the same issue. It seems to be a bug. There's an easy way to fix it. Just play a sound, before playing the video.
    I just added a short sound file that I'm playing onLoad. Without this, Flash doesn't seem to know how to handle sound in video files, but once you played a sound, it "remembers" how to do it for stagevideo.
    Silly solution, but it worked for me
