3D text issues (auto-transparency?)
Apr 26, 2012 7:50 AM
Tags: #3d-text #text_transparency_problem
So I may be the only one playing with CS6 that is having this problem and I may be doing something wrong BUT when I create a basic 3D text object it somehow is somewhat transparent.  It looks almost like it has a blending option chosen but it is clearly on normal.  I am not understanding why I am having this problem.  Here is a picture of what I mean.
http://img441.imageshack.us/img441/9286/screenshot20120426at934.png
    Apr 26, 2012 9:04 AM   in reply to theZJayRichards
    Are your graphic card drivers up to date? Is that text layer above the yellow layer in the Layers Panel?
    Apr 26, 2012 9:18 AM   in reply to theZJayRichards
    Does this happen in other documents, or just this one? If you can, can you provide the file for us to take a look at?
    Apr 26, 2012 9:21 AM   in reply to Howard Pinsky
    One more idea. Is the source text okay? In your 3D Panel, select the "Any..." element, then press "Edit Source" in the Properties Panel. Make sure the 2D text has a 100% Opacity, and the Blending Mode is Normal.
    Apr 26, 2012 9:37 AM   in reply to Howard Pinsky
    My quick guess is that your materials somehow are set to Opacity >100%. I say this because both the front face and the side extrusion are showing the lower layer artwork. I can't quite tell but it looks like the bevels are still fully opaque.
    Go to the 3D panel and target one or all of the text extrusion materials, then look at the Opacity value in the Properties panel. Set the value to 100% explicitly.
    regards,
    steve
    Apr 26, 2012 9:53 AM   in reply to SG...
    So I'm not sure how you built the file, but I think the problem stems from the color mode of your document. Do you recall how you were able to get a 3D layer into the CMYK doc?
    Also, beware that converting it back to RGB may crash Ps. I'm looking into your file now with various platforms.
    regards,
    steve
    Apr 26, 2012 12:18 PM   in reply to theZJayRichards
    The 3D features really should only be used in RGB. You found a hole that we need to fix.
    For cases where you have RGB 3D and convert to another mode, Ps displays a dialog asking if you want to flatten any 3D layers (so no need to rasterize). For your existing file, you can create a new RGB doc at the same pixel dimensions, and then drag the 3D layer ("ANYTHING") over to it. Now delete that layer in your original file, and then convert to RGB. Now drag the 3D layer from the new doc back into your converted to RGB doc.
    Sorry for the trouble and hope this keeps you from having to redo too much work.
    steve
