Unable to build iOS in Flash Builder 4.6
Feb 16, 2012 10:53 PM
Tags: #mobile #ios #compile #deployement #flash_builder_4.6
I have created iOS before with the flash builder 4.6 but today when I try to create Flash builder will start after it ask if I want to overwrite exsisting api file and then after 5 minutes, the bar never moves the hourglass is going, it close the "Export Release Build" window.
No errors and not the window telling that have build api file.
Using Windows 7 64
Any one have the same problem?
Kim
    Mar 5, 2012 10:36 AM   in reply to KimHJ50
    Exact same problem.  After a half hour of "packaging", hourglass is still going, and packaging is at 0%.
    Mar 5, 2012 12:06 PM   in reply to hungrybeagle
    Nvm...
    It just took a really long time; I left it, went to make/eat breakfast and it was done an hour later when I returned.
    Mar 10, 2012 10:29 AM   in reply to KimHJ50
    It does take a long time, I have 40MB project that takes ~16 minutes for the IPA and less than 1 minute for the APK.
    Mar 26, 2012 9:30 AM   in reply to KimHJ50
    I am having the same problem. It tries to compile and just hangs. I have let it run overnight. the project is about 30MB, it compiles apks fine though. I really need to find a solution so any help at all is appreciated.
    Apr 26, 2012 6:50 AM   in reply to KimHJ50
    Oh my... that's so sad - I so hoped there would be a solution to my problem (I've got the same like you all), but there seems to be no answer...?
    I tried updating from Flash Builder 4.5 to 4.6 (even deinstalled the 4.5 before installing the new one), but nothing changed.
    Apr 26, 2012 10:36 AM   in reply to KimHJ50
    This is the error that I have. Is the same with you?
    Apr 27, 2012 1:01 AM   in reply to luciano.bustos
    I think that you have another error. With me (and I think with the others before me, too) there is no error message at all. Flash Builder keeps on "generating" and "generating", but nothing really happens and the .ipa is never published. But sorry for your error - the message is not very meaningful, either...
    Apr 27, 2012 4:56 AM   in reply to KimHJ50
    I was not getting an error message. I did finally get it working. I believe it was something in the provision file. After I downloaded a new one and used that it compiled normally.
    Apr 30, 2012 6:45 AM   in reply to batiesphoto
    I found out that there was something wrong with some certificate or key (don't know which exactly).
    I tried building the .ipa with the cmd (I'm on Windows) and there I got an error message saying so.
    Because I generated the certificates and keys with a Mac but intended to use them on Windows for developing something went wrong, I think. I then followed the steps for creating them on Windows described here and with those finally the .ipa was generated.
    May 5, 2012 12:24 PM   in reply to KimHJ50
    I am having a similar problem while trying to export the mobile application for iOS, i tried all sorts of combinations with the certificates, since it works on simple and smaller applications, but for some it does not.
    Also, a couple of days earlier, i was able to compile the same ios release build, but today it is just frustrating me and getting stuck at packaging (0%)
    Sep 8, 2012 5:51 AM   in reply to KimHJ50
    I'm trying to solve the exact same problem some days . No results. The app is build well in fast debug mode and then work correctly. But in standart debug mode is not packaging. I've tried dozens of options, cut off the library, check the library provision and certificates to an empty project - all well. Do not understand what I can to try and where to look for a solution.
    Mar 3, 2013 7:09 AM   in reply to KimHJ50
    I have the same problem with Flash Builder 4.7
    Moving source to new project helped
