nigelwalker38
Aspect Ratio. Page and Folio
Apr 26, 2012 12:13 PM
I'm trying to Preview in Content Viewer from the Overlay Creator and I keep getting 'The page size aspect ratio must match the folio aspect ratio'.
The file is an original file from a Lynda tutorial. It has not been altered. It is horizontal in orientation.
The same file exists in vertical orientation which does open in the content viewer.
This is very confusing. I've tried only having the horizontal file open. I've resetted ID etc.
The problem is I can't continue with the tutorials and no where can I find information on folio aspect sizes.
Thanks.
Nigel.
  • Casey Jensen
    May 4, 2011
    Apr 26, 2012 12:53 PM   in reply to nigelwalker38
    Hi Nigel,
    What did you set the Folio aspect ratio to? (In the Folio Builder Panel, select the folio -- then go to "Properties" on the drop-down carrot.)
    Let's say for instance that you set the folio to 1024x768. Your InDesign pages should then be 1024x768. If you're doing both landscape/portrait versions, then you need to ensure the Orientation setting is set appropriately on each file (File->Document Setup.)
    You should then be able to do an "add" with the InDesign file open (Folio Builder panel drop-down carrot) to add it to the folio. Alternately, you can name the landscape file with a _h, the portrait file with a _v, and place them both within a folder. You can then import both by going to the drop-down carrot and selecting Import..
    Casey
    Apr 26, 2012 5:50 PM   in reply to nigelwalker38
    I found your question because I've spent the last 4 hours trying to solve this same issue. In my case I began Adobe's tutorial following the steps in the tutorial pdf to a T. (Adobe® Digital Publishing Suite Hands-On Tutorial). When working with the ..._v.indd file, no issues. But when opening the "2Wheels_start_h.indd" file, clicking on Preview in the Overlay Creator palette gave that same warning. The only thing that works is to create a folio, add the article, then click the Preview on the "Folio Builder" palette.
    To recap: On the tutorial using the provided files "Part 2: Use the Overlay Creator", Number 10 "Click Preview at the bottom of the Overlay Creator panel to launch Adobe Content Viewer for Desktop" gives the warning "The page size aspect ratio must match the folio aspect ratio".
    Please help. I'd really like to get past step 1 and learn how to use it.
  • Casey Jensen
    May 4, 2011
    Apr 26, 2012 5:59 PM   in reply to FritzMiller
    Can one of you post the sample file?
    Apr 26, 2012 6:08 PM   in reply to Casey Jensen
    Hi Casey. You can download the tutorial here.
    http://www.adobe.com/devnet/digitalpublishingsuite/articles/digital-pu blishing-suite-hands-on-tutorial.html
    Download the tutorial sample files: DPS_Tutorial_Assets.zip
    Problem occurs at Part 2, No. 10 of the tutorial pdf doc "DPS_Tutorial_Design.pdf".
    Thanks for your help!
  • Casey Jensen
    May 4, 2011
    Apr 26, 2012 6:18 PM   in reply to Casey Jensen
    Looks like a bug with the Overlay Creator panel. Go to File->Folio Preview instead. There are some bugs with the v19 viewer as well, so you won't be able to scroll through all of the pages in the stack. You could just break the layout up into a smaller number of pages.
    Apr 26, 2012 6:25 PM   in reply to Casey Jensen
    Always reassuring to know it's not me.
    Thanks for your super-quick response. I can move on now.
    Thank you Casey.
  • Casey Jensen
    May 4, 2011
    Apr 27, 2012 4:52 AM   in reply to nigelwalker38
    No problem. Good luck on your learning!
    May 17, 2012 6:41 PM   in reply to Casey Jensen
    Had the same issue while on Lynda.com here is the fix:
    1- Go to window - extensions - folio builder
    2- click on the upper right triangle on the folio builder and select new
    3- Name the folio _h and select portrait only for the the orientation
    4- Then hit ok
    5- Now go back to the overlay creator and click preview
