zoomiejub
I can't find my saved photos?
Apr 26, 2012 5:30 PM
I just bought Photoshop CS5  this weekend, so I'm brand new to everything. I had edited a photo of my sister last night and went to save it by "save as" and I had made a seperate folder in my "pictures" library. Today I went to pull up the photo to show my sister, but the whole folder wasn't even there. So I went in and re-edited the picture and saved it, recreating the folder and paying closer attention to what the picture was saved as (at the time I first saved it I hadn't realized that it was saved as a .PSD so this time I made sure that I saved it as a .JPEG). Still the folder itself isn't showing up. How can fix it/what am I doing wrong?
All help is VERY much appreciated.
Thank you!
Bridget
    Apr 26, 2012 6:33 PM   in reply to zoomiejub
    What OS are you using?  If Mac do you use iPhoto?
    Can you get back to the folder you saved it to?  Is the folder empty?
  • Noel Carboni
    Dec 23, 2006
    Apr 26, 2012 9:13 PM   in reply to zoomiejub
    Look carefully and double check the location when you open the File - Save As dialog.  Make sure it's not on another computer in your network or something.
    -Noel
    Apr 26, 2012 10:15 PM   in reply to zoomiejub
    Hmm, I am wondering if the new folder was linked to the library. that would explain why you can see the folder in photoshop and not from explorer.
    Try this (assuming your on windows 7) Click on the windows start button (where your programs are listed) At the bottom of that menu is a search box.
    Type in the following:
    *.psd
    or
    This will bring up a list of all the psd or jpg files on your drive. You can then double click on the file to open the image in HP's image viewer.
    Also if you right click on the file, you will find (open) on the menu minus the parentheses clicking on open will allow you to choose from various programs like photoshop, HP image viewer, windows fax and image viewer, internet explorer and so on.
    Generally on a windows system, most if not all pictures are stored in the pictures folder. Though they can be stored anywhere and linked to the library.
    Also take a look at the trash can and see if there is trash in it. Any files that are deleted to to the trash can where you have the chance to restore the files if you made a mistake.
    Good luck, i hope you find your pictures...
    Apr 27, 2012 4:52 AM   in reply to zoomiejub
    Did you also look in the Recycle Bin ("Trash Can") as suggested by Silkrooster above?
    Also try a free file finding utility like "Everything" : http://www.voidtools.com/ that will look everywhere on your drive, even places off limits to the system search engine.
    Another choice here:  http://www.replsoft.com/
  • Noel Carboni
    Dec 23, 2006
    Apr 27, 2012 5:46 AM   in reply to zoomiejub
    Please heed post number 3.  There's no reason to be searching!
    Unless you have a serious problem, your computer is saving your files somewhere, and you just need to figure out where that is.  Searching your system in the hopes of finding something you can determine directly and in a few seconds is silly.
    • Start Photoshop and open one of your images from the Recent Files menu.
    • Choose File - Save As.
    • Click on the selector at the top and see exactly what folder you're about to save a file into.
    If you cannot figure out how to read that folder tree, then your problems are way beyond Photoshop, and you need to do some reading on how to use Windows.  Do a screen grab as I did above and we can help you interpret it.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 27, 2012 1:40 PM   in reply to zoomiejub
    zoomiejub wrote:
    This isn't a problem of my not saving it in the wrong place. I KNOW where I'm saving it.Save As> Recent Items>Pictures>(New folder)Edit.
    That's not an actual folder.  Windows throws around all these Library abstractions, and all it does is cause confusion.  I believe you are creating your new "Edit" folder somewhere you didn't expect.
    Try this instead:  Pick a folder that's rooted on one of your actual hard drives under Computer, as I have shown above.
    Avoiding the abstractions entirely is one sure way of avoiding this kind of confusion.
    The little lock symbols are essentially useless and can be ignored.  They have to do with sharing folders with other computers on your network.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 27, 2012 1:42 PM   in reply to zoomiejub
    I just noticed that the dialog you're seing says "Place" at the top, and not "Save As".  Why is that?  How EXACTLY did you cause that dialog to open?
    -Noel
