Adobe Bdobe
DO I NEED AIR 3.2?
May 1, 2012 11:45 PM
I am updating (adding to) the below posting -- it's been 4 days since posting it and I'm puzzled why no one has responded to it.
It appears that Chris and/or others have responded to other posts since my posting.  Was what I was asking below unclear?
I am confused by the reference indicating that AIR is part of the OS and, as such, downloading Air 3.2 is unnecessary.  Again -- my basic hypothesis is that since I have an earlier version of AIR installed, and no OS upates have changed that version to AIR 3.2, is the statement that AIR is part of the OS inaccurate?  If so, is it logical that I should download and install AIR 3.2 to have the latest version on my system?
Finally, are all these other posts about problems installing AIR something I should seriously be concerned with or are they just a minority experience, with most AIR installations successful?  (I would think that Chris, as an Adobe employee, would have credible comment on that.)
Looking for some support, please!  Thanks!
I have Windows 7 Home Premium (with Service Pack 1) on a Dell XPS 8300.  Air 2.6.0.191.20 was preinstalled on my machine by Dell on 8/17.2011.
So about half a year later I discover Air 3.2 is available for downloading and installation.  I've received no automatic prompts regarding installing it.  But nonetheless, upon a cursory overview of online information I've decided that Air is worth having, and, yeah -- why not go with the latest version?
But -- on an Adobe web page (http://www.adobe.com/products/air/tech-specs.html) it says, "Note: Adobe AIR is part of the operating system and part of the operating system update, and thus a separate download is not required."
Huh?  (Then why haven't numerous Windows 7 updates since delivery of my pc shown an upwards revision of the version of Air in my system?)
Then -- adding to my confusion and general sense of caution -- I see nuerous posts regarding difficulties with installing Air.
Adobe's "Chris" seems like a good guy -- wanna help me out, please?!  Bottom line -- should I download and install Air 3.2?  Or, if pros and cons get too dicey, am I at least able to if I want the latest version?
  • Chris Campbell
    May 4, 2010
    May 2, 2012 12:12 PM   in reply to Adobe Bdobe
    Sorry I hadn't gotten to your post yet.  I'm behind and still going through posts from a week and a half ago
    AIR isn't required for your operating system unless you use an application that depends on it.  Think of AIR like you would Java.  It's a platform/runtime for other applications to be built on.  If you don't use any application that was built with AIR (or Java) then there is no need for it to be installed.
    If you do have an AIR application installed that requires AIR, I would definitely recommend updating to the latest version just to make sure you have all of the security updates that we've provided.  You can do this by visiting get.adobe.com/air and downloading the latest version, which is 3.2.  Updating your OS will not update the AIR runtime.  You can also get updates by actually launching your AIR based applications.  AIR will notice that it's out of date and prompt you to install and update to the latest version.
    Since you haven't received any AIR update notifications, this leads me to believe you aren't actually using any AIR applications.
    You can always start the AIR uninstall process, if AIR applications are installed you'll get a dialog letting you know which applicaiton's will be affected.  You can choose to continue to uninstall or cancel at that point.
    Hopefully this makes sense.
    Chris
